02-08-2018 03:07 AM - edited 03-17-2019 12:09 PM
Hi all,
I'm in charge of a project for setup a Disaster REcovery solution for our UC application.
We are running different CUCM cluster (with CUC and IM&P + Expressway additional services) and I would like to understand which is the best solution to provide a DR on a different geographical site from our actual Data Center.
CUCM are all 11.0.x release and, of course, all deployed on UCS server in virtual environment.
From cisco docs I understand that:
- VM snpashot for UC application is not supported (for high resource usage and impact on RT services)
- VM cloning is not supported: will it invalidate licenses?
So it seems that the only way to make a backup and restore is to use DRS features on all cluster, then reainstall the VM and restore a valid backup.
Can you please confirm all of these considerations?
I'm also considering the option to deploy a cluster over the wan with an Active - Active topology between the Data Center and the DR Site.
REgards
FRancesco
Solved! Go to Solution.
02-08-2018 06:12 AM
This is correct, the only supported backup method is using DRS.
02-08-2018 06:12 AM
02-08-2018 07:01 AM
Cloning is supported, the caveat is, you'll need to shutdown the VM every time you want to clone it as you cannot do this with the VM running.
