02-07-2018 02:12 PM - edited 03-17-2019 12:08 PM
Hi all. I would like to know... you can add a DX80 to CUCM 10.5; you can add to Cisco TelePresence Server the same endpoint. So, what is the difference?? you can add to **bleep** the telepresence endpoint but you will lose some kind of functions? is there a benefict with Cisco TelePresence Server only??
Many thanks!
Solved! Go to Solution.
02-08-2018 06:48 AM
You need to be at 10.5(2) and install the required DevPack or the latest SU to be able to use them with CE load, 10.5(2) should already have the option to use them as Android devices.
02-07-2018 02:52 PM
So, what are you really asking here???
CUCM and VCS are call control
vTP server is a video bridge, not call control and you do not register devices to it.
02-08-2018 06:02 AM
Hi, Many thanks for your answer. i would like to know what is neccesary to register a DX80 on a CUCM 10.5 because i usually see that MCU or telepresence server is integrated with CUCM.
Can i register DX80 on CUCM 10.5 only? what are the limitations?
Many thanks!
02-08-2018 06:48 AM
