01-13-2016 09:21 AM - edited 03-17-2019 05:29 AM
Is there any difference between CUCM and CUBE SIP messages? I tried to integrate Paging system (supports SIP) with our IPT solution. First I tried the following call flow:
CUCM => SIP Trunk => CUBE => SIP => Paging System
When I dial from IP phone, it keeps ringing and no answer. (Should open immediately and page)
Once I changed the IP address of the SIP trunk in CUCM to the paging system IP address, it worked.
But the customer requirement to keep the integration through the CUBE. Could you please help?
01-13-2016 09:32 AM
Please share the output of debug ccsip messages of failed call.
01-13-2016 09:42 AM
01-13-2016 09:51 AM
10.11.3.220, where this IP is assigned?
Did you take complete logs? I can not see logs after paging server sends 200 ok.
Can you also share the traces of working call?
01-13-2016 10:41 AM
This is another IP in the PAGING, and no changes from Paging side.
All what I did is changing the IP Address in CUCM from CUBE to paging.
01-19-2016 10:19 AM
Sorry, to reply late. Today I was able to meet with Paging system team to work on the integration.
All, what I did today is to change the IP address in the dial-peer to point to the address that I saw in contact header. Everything is OK now.
Before the OK message was:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.6:5060;branch=z9hG4bK482022;received=192.168.1.6
To: <sip:111@192.168.1.222>;tag=as7872fa82
Call-ID: 2E7DB3D1-BDE411E5-9388A668-FAC54363@192.168.1.6
CSeq: 101 INVITE
Server: Asterisk PBX 1.6.2.24
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces, timer
Contact: <sip:111@192.168.1.220>
Content-Type: application/sdp
Content-Length: 228
Then I adjust the dial-peer to point to 192.168.1.220 rather than .222
But my question is why CUCM accept this while CUBE no?
01-13-2016 11:26 AM
01-13-2016 12:00 PM
The log is not complete. We do not see the CUBE sending 200 OK back to cucm.
First of all we need to change the sip transport protocol to ensure we use the same protocol for the whole call. Currently we have cucm using TCP and CUBE using UDP.
Lets try this
1.configure the dial-peer facing the paging system to use tcp as the transport protocol
dial-peer voice xxx voip
session transport tcp
Test again and send us debug ccsip messages
01-13-2016 12:14 PM
Thank you too much +5
Could you please share with me other possibilities?
I left the site and I will try tomorrow, so I can try more than one option.
01-13-2016 12:16 PM
We can only proceed once we see the logs. So please get in touch tomorrow when you are onsite and hopefully we can resolve this.
01-13-2016 12:20 PM
I forgot to say that I saw the following message from CUBE to CUCM after keep ringing for long time:
Sent:
SIP/2.0 500 Internal Server Error
Via: SIP/2.0/TCP 10.10.10.100:5060;branch=z9hG4bK5ffd8243cae75
From: "Paging Test" <sip:200@10.10.10.100>;tag=769323~680d56b4-4710-48e9-ba27-660f9e697be4-142047552
To: <sip:170@192.168.1.6>;tag=9B696E68-C82
Date: Wed, 13 Jan 2016 15:25:12 GMT
Call-ID: e737180-69616cb8-5db23-36c9200a@10.10.10.100
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.5.1.T2
Reason: Q.850;cause=16
Content-Length: 0
01-13-2016 12:27 PM
It was ringing for a long time because the sip messages were not complete. Hopefully we can find a solution tomorrow
