CUCM with NEC SV8300 PABX with SIP trunk
naresh_lalchand
Hello ,
Request for ANY white paper or previous experience to link the 2 system by SIP trunking ?
will be a great help
TimHuffman
Hi Naresh,
Were you ever able to find documentation?  I'm looking for the same information.
Tim
naresh_lalchand
So sorry for my late reply.
I did not get any response.
I am still figuring out.
i think if the other end support SIP just make sur eyou are using the right SIP attributes like
non-secure SIP, SIP port
also CUCM for incoming support both TCP and UDP SIP
but for inbound it support one of then at a time so check the PBX what SIP it use TCP or UDP and change it to be compatible other than this it supposed to be standard, start your config with SIP trunk without MTP required Not checked
if dose not work try software MTP using MRGL assigned ot the SIP trunk
good luck
if helpful Rate
Are you still working on this?  I am looking for a solution with the SV8500 PBX.  I found on the NEC website that the 8500 is a SIP trunk certified solution, but i have still to find some type of integration guide.
http://www.necunifiedsolutions.com/main/support/supSipTrunk.asp
