CUCM7.1 called Party transformation
tkavithas87
In the called party transformation pattern page of CUCM7.1 ,The field discard digit is grayed out.what could be the cause?
thanks
kavi
Ayodeji Okanlawon
This is most likely because the pattern you have configured does not have any possible digit to discard...
To use the discard digit you need to have some for of "@"  "." or "#"
With a pattern like this..
4#
4@
4.
You can use discard digit.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Ayodeji Okanlawon
4#
4@
4.
thanks    aokanlawon.you are correct
