CUCM8.6+CP-8800-A-KEM
Hi Guys ,
IS that possible to add support of CP-8800-A-Kem module to CUCM 8.6 ?
Ratheesh Kumar
Yes it is.
As per the data sheets its supported.
Table 3.       System Requirements
Phone Firmware/Call Control Server
Release
Cisco IP Phone 8800 firmware
10.2(2) and later
Call-control compatibility
Cisco Unified Communications Manager Version 8.5(1) and later; and Cisco Unified Survivable Remote Site Telephony (SRST) 8.0 (with Cisco IOS® Software Release 15.1(1)T) and later
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/ip-phone-8800-series-key-expansion-module/datasheet-c78-732356.html
Cheers
Rath!
***Please rate helpful posts***
A-KEM is different than BKEM . A-KEM = 28 buttons , BKEM =36 . On CUCM 8.6 we see only BKEM , so question is was how to add  CP-8800-Audio 28 Button to CUSCm 8.6? Is any device pack for that ?
The only reference on the new KEMs (A & V) seems to be in 11.0.1. So my assumption, you might need to upgrade the CUCM to 11.X
 "QED checkin for CP-8800-A-KEM and CP-8800-V-KEM"
https://www.cisco.com/web/software/282074299/139919/cmterm-devicepack11.0.1_24081-1_Release_Notes.pdf
I prefer you open up a PID Case with Cisco at www.cisco.com/go/pdi
Cheers
Rath!
Hi ,
Thanks so much . We prepare for upgrade
