02-28-2013 01:59 PM - edited 03-16-2019 03:59 PM
Guys,
I am trying to use DNS SRV records with my CUPS9.1 sip trunk. However CUCM is not able to resolve the dns name to an ip address..
On CUCM when I do utils ping hostname, it does resolve it to the correct address and ping is succesful. However When I use either DNS name or DNS SRV name in my sip trunk, it fails. The logs show this..
+++++++++WITH DNS SRV Records ++++++++++
00010367.003 |14:56:31.883 |AppInfo |SIPDns - wait_SdlDnsSrvRecordRsp: (DNS A or AAAA query called as SRV query Fail):hostname=presence.uclab.com, ReqType=1,serversused=0
00010368.000 |14:56:31.883 |SdlSig |SdlDnsSrvRecordRsp |wait |SIPDns(1,100,73,1) |SdlResolverService(1,100,5,1) |1,100,73,1.8^*^* |*TraceFlagOverrode
00010368.001 |14:56:31.883 |AppInfo |SIPDns - wait_SdlDnsSrvRecordRsp: Received SdlDnsSrvRecordRsp ReqCode is -1
00010368.002 |14:56:31.883 |AppInfo |SIPDns - copySdlDnsSrvRecordRspToSpi: ReqType is 1
00010368.003 |14:56:31.883 |AppInfo |SIPDns - wait_SdlDnsSrvRecordRsp: (DNS A Query Fail)
++++++++ WITH DNS used only++++++++++
00023074.000 |16:51:26.840 |SdlSig |DMPropagateRegister |initialized |DMPropagation(1,100,205,1) |DeviceManager(1,100,199,1) |1,100,37,1.29^*^* |[T:N-H:0,N:0,L:0,V:0,Z:0,D:0] Name=CUPSTRUNK Cepn=6a8ff5c1-6d83-05fd-9448-1c3185d7be06 Protocol=SIP Trunk Pid=1,100,74,6
00023075.000 |16:51:26.840 |SdlSig |SIPSPISignal |wait |SIPHandler(1,100,72,1) |SIPDns(1,100,73,1) |1,100,73,1.43^*^* |*TraceFlagOverrode
00023075.001 |16:51:26.840 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/wait_SIPSPISignal: Received DNS query response with no hosts for context_id=0
This is quite puzzling because using nslookup, I have checked that the SRV records work and infact my jabber clients loggin using SRV records.
CUCM has DNS ip address configured and when doing pings can resolve dns host names...
Any thougths please?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Solved! Go to Solution.
03-01-2013 07:45 AM
Definitely sounds like something on the DNS then. Do you have reverse lookup properly defined?
Chris
02-28-2013 04:00 PM
Deji,
Can you post a screen shot of your DNS record?
So SIP trunk to CUPS server is configured with SRV record of "presence.uclab.com", is "presence" a sub-domain in uclab.com domain? Is it TCP or UDP, and I am assuming it is built with port 5060?
Chris
03-01-2013 02:56 AM
03-01-2013 06:42 AM
Can you post output of nslookup?
Also, did you change the SRV domain name under Proxy service parameters in IMP server?
Chris
03-01-2013 07:05 AM
03-01-2013 07:13 AM
Hmm, all looks good.
Is the SIP security profile configured to use TCP?
Is it possible for you for testing to add the SRVs to the domain not subdomain and then point SIP trunk to uclab.com?
Have you tried pointing to FQDN of one of the IMP servers just to see if DNS works for it?
HTH,
Chris
03-01-2013 07:34 AM
Using the FQDN od the IM&P server doesnt work either. This is what is puzzling. The same hostname can be resolved when you do a ping but cucm cant resolve it when it attempts to send a PUBLISH for phone offhook status.
I have also tried using the parent domain uclab.com..No joy!
03-01-2013 07:11 AM
Attached also SRV cluster name config...and ping from cucm to hostnale of IM and presence server
I just think that the issue is CUCM not resolving DNS name. Even when I change destination on the sip trunk to cimpspub.uclab.com
03-01-2013 07:38 AM
Does it work with IP address?
Chris
03-01-2013 07:40 AM
Yes!
03-01-2013 07:45 AM
Chris
03-01-2013 08:18 AM
Chris (+15 all round)..You are my star!!! Would you believe it, I created a reverse lookup for my backup IM&P server which is not up at the moment and I dint create one for my active server. It muyst have been a mistake...Now the logs look like this..
00053007.001 |15:27:24.217 |AppInfo |SIPDns - convertQueryType: Converted Query ReqType 33
00053007.002 |15:27:24.217 |AppInfo |SIPDns - copySpiToSdl: DNS req type 8, query preferred type 0
00053008.000 |15:27:24.218 |SdlSig |SdlDnsSrvRecordRsp |wait |SIPDns(1,100,73,1) |SdlResolverService(1,100,5,1) |1,100,73,1.152^*^* |*TraceFlagOverrode
00053008.001 |15:27:24.218 |AppInfo |SIPDns - wait_SdlDnsSrvRecordRsp: Received SdlDnsSrvRecordRsp ReqCode is 0
00053008.002 |15:27:24.218 |AppInfo |SIPDns - printRRlist: ***SRV Record: priority 0 weight 0 port 5060 name cimpspub.uclab.com
SIPDns - copySdlGetHostByNameRspToSpi: aFamily 2
00053009.002 |15:27:24.219 |AppInfo |SIPDns - wait_SdlGetHostByNameRsp: hostname=cimpspub.uclab.com, IP=192.168.131.15:5060, next query=0
And then I get my Publish message sent out..Cool
00053012.001 |15:27:24.219 |AppInfo |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 192.168.131.15 on port 5060 index 201
[955,NET]
PUBLISH sip:bbanks@uclab.com:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.131.11:5060;branch=z9hG4bK5029cbda79
To: <>>bbanks@uclab.com>
Call-ID:
82fe9b80-1301c8dc-22-b83a8c0@192.168.131.11
03-01-2013 08:38 AM
Chris,
Another thing I noted is that phone presence works even without defining the SRV Cluster name
