09-22-2016 04:33 AM - edited 03-17-2019 08:09 AM
I'm running several CUCME with the latest 11.5. According to the compatibility guide there is only a support for Jabber 9.2.1 in "phone-only" mode which is no longer availible.
Which combination between CUCME 11.5 and Jabber is supported/working ?
Many thanks
Markus
09-22-2016 05:07 AM
CME 11.5 should be able to support jabber check below.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme115spc.html
Cisco Jabber for Windows (Full UC Mode) |
Jabber - 9.1.0/ WIN-7 64 bit and WIN-XP SP3, 32 bit |
JB
09-22-2016 05:53 AM
I saw the Jabber 9.1.0 statemt also. Issue is that this Version of Jabber is not availible for download since quite a while now.
I will take the advice from Aseem and open a TAC, unless somebody does have some other ideas.
Markus
09-22-2016 05:31 AM
Unfortunately there is very little support on CME for Jabber for windows. I would suggest you to open a TAC case and get it confirmed.
Aseem Anand
