11-09-2021 09:56 PM
I have installed CME 12.0 on CISCO 2911 with CUE module, all the SIP phones are registering properly and working fine. The CUE module is also configured and working fine with the voice mailboxes. I have also configured the Auto Attendant with 7001 Number. When I am dialing 7001 the AA service responds and ask me to dial 0 for operator when I am dialing 0 it doesn't responds, I mean pressing 0 or any other number like 1 to transfer extension does not give me a beep tone as well.
Any help will be appreciated.
Solved! Go to Solution.
11-10-2021 03:58 AM
Also apply the dtmf-relay rtp-nte to your voice register pools too.
11-09-2021 10:58 PM
Its a DTMF issues. Check if you have DTMP-relay configured on dial-peers.
11-09-2021 11:03 PM
Hello Nitin,
Please check the below Dial Peer which I have made and let me know how can it be resolved.
dial-peer voice 7000 voip
description VoiceMail
destination-pattern 7000
session protocol sipv2
session target ipv4:192.168.200.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 7001 voip
description AutoAttendant
destination-pattern 7001
codec g711ulaw
no vad
dial-peer voice 7002 voip
description AVT
destination-pattern 7002
codec g711ulaw
no vad
11-10-2021 02:59 AM
Use dtmf-relay rtp-nte instead of dtmf-relay sip-notify.
11-10-2021 03:28 AM
The beep voice is coming now but when I press 0 nothing happens.
11-10-2021 03:31 AM
have you configured your AA properly ?
11-10-2021 03:48 AM
Nitin I have posted the configuration please have a look and let me know
11-10-2021 01:48 AM
Try setting the dtmf-relay setting to rtp-nte instead of sip-notify.
There are quite a number of similar posts on the community over the years where this ended up being the fix for them.
The other thing you can try is adding the rtp-nte in addition to sip-notify. It might be better to just pick one though!
11-10-2021 03:34 AM - edited 11-10-2021 07:09 AM
a
11-10-2021 03:58 AM
