CUCME functions on CUCMBE
We just migrate from CUCME to CUCMBE, and I just can see how works or if it's support it this functions:
- Paging
- Monitoring a DN
Can I do this on CUCMBE??
2 Accepted Solutions
William Bell
CUCMBE can monitor a directory number. One phone can monitor the line of another phone using Busy Lamp Field (BLF) feature. This can be extended to the directories (missed, received, placed calls) as well.
As far as I know, group paging is not supported on CUCMBE natively. You may be able to use a separate product (e.g. Cistera) though I don't know if there would be official support for CUCMBE.  CUCMBE can do intercom between phones.But that isn't the same thing.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
There is no paging in any CUCM or CUCMBE version.
That requires a 3rd party application.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
William Bell
HTH.
Bill
Thanks William for your answer, you are right but this monitoring line function on CUCME is the best, cause you could see when the line was off hook, when there was a VM for the user, when it has CFA enable, etc.  And on CUCMBE only works as a speed dial, or at least that's the way it's working with me, is this correct??
Sorry I forgot to mention that paging function is enable on CUCME without any external device, I understand what you said, but I was wondering if this function was enable the same way as in CUCME.
java
java
