09-30-2009 10:54 PM - edited 03-18-2019 10:40 AM
Hi all,
I need to upgrade a AIM-CUE 3.1, to hopefully 7.1.x. question:
1, according to Cisco docs, if the AIM-CUE has got 512MB compact flash, it needs to upgrade to 1G first. how do I check the how much is the flash now? I went through all the commands and even "show tech" on the module, can't find the flash size.
2, if I do a upgrade (not clean install), do I need to do anything about licenses??
thanks
Solved! Go to Solution.
10-01-2009 08:17 AM
1. you can use show voicemail limits
if System Capacity (minutes): 480
then it is 512
480/60=8-hours storage
if 14-hour storage ,then it is 1GB
2. no
wish this be helpful
10-01-2009 08:17 AM
then it is 512
2. no
10-01-2009 12:48 PM
hi,
this may clarify my post above:
CUE#show voicemail limits
Default Mailbox Size (seconds): 420
Default Caller Message Size (seconds): 60
Maximum Recording Size (seconds): 900
Default Message Age (days): 30
Default Prompt Language: en_US
Operator Telephone: 0
10-01-2009 09:30 PM
Thanks! I ran that commands, it shows the system capacity as 800 min, so I guess it's a 1GB flash one.
For the license, I found that since CUE 7.1, the licensing changes to the new scheme, you buy the mailbox license in increments of 5, etc. I thought since it's different from before, don't you need to get new license file or something like that??
10-02-2009 06:53 AM
yes
I have an upgrade like that lately
and i didn't deal with any upgrade license file
it is only if you'll change the no. of supported mail boxes
thanks
10-01-2009 10:02 AM
I believe you can see compact flash information with show version from cue prompt.
Hope it helps, if it does please rate.
Best regards,
- Adrián.
10-01-2009 09:34 PM
thanks for your reply, I thought the show version command would show it, but it shows SDRAM not flash size.
10-02-2009 06:32 AM
Thanks for your confirmation.
- Adrián.
