06-23-2013 04:18 AM - edited 03-16-2019 06:02 PM
In our organization we recently migrated one site to another cluster. Everything is working fine apart from the CUE is not working correctly
CUCM 8.6
CUE 7.0
CUE can negotiate with weblogin and jtapi fine and also all CTI ports are registered but some reason CTI ROUTE POINT is not registered. I have done following things but no luck.
Please help me where I am wrong
Restarted CTI Mangaer
Restarted CUE couple of times
Associate and deassociated jatapi account
But no luck
Solved! Go to Solution.
06-23-2013 04:46 AM
1.check the jtapi user associate with cti route point
2.make sure the cti route point DN number same as you configured in CUE
Sent from Cisco Technical Support Android App
06-23-2013 05:01 AM
check the Voice mail > Call handling: Voice mail phone number.
By the way, did you check whether this combination is supported at all - I mean CUCM 8.6 and CUE 7
G.
06-23-2013 04:46 AM
06-23-2013 04:56 AM
Hi johchen,
Thanks for your reply,
Yes I can confirm jtapi user associated with cit route point
Sorry I am not sure what do you mean. For example if cti route point DN number is 88888 how we can configure in CUE. Do you mean as a user?
If you dont mind can you please explain this point?
06-23-2013 05:01 AM
G.
06-23-2013 05:11 AM
I was missing to update voice mail phone number. Thanks guys of your great help
