05-18-2012 08:54 AM - edited 03-16-2019 11:14 AM
I have a UC500 with an AIM-CUE and I get many errors when I attempt to boot it up, so I am trying to install version 7. I have a Vlan that acts as the default gateway on the router, and am utilizing the IOS DHCP server, which successfully hands out IP's addresses to clients. From my workstation I can ping the default gateway on the vlan and the service-module.
My default gateway is 10.225.25.1
My workstation IP is 10.225.25.3
The bootloader IP address is 10.225.25.5
However, I can not ping anything from the bootloader command prompt of CUE, including the loopback, which is why the TFTP file transfer is failing. I don't have many configuration options, anyone have any ideas?
05-18-2012 09:03 AM
Sounds like a routing issue. Can you post your config?
05-18-2012 09:13 AM
! Last configuration change at 15:07:39 UTC Fri May 18 2012
version 15.1
service config
no service pad
Hostname router
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/2
enable secret 5 ***************
no aaa new-model
crypto pki trustpoint TP-self-signed-1663708721
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1663708721
revocation-check none
crypto pki certificate chain TP-self-signed-1663708721
certificate self-signed 01
3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31363633 37303837 3231301E 170D3132 30353137 32313331
33355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 36363337
30383732 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C350 B0044519 09EB64EA 38F9CB65 305DEDA9 E5C4DF79 8EADD739 EC31C41B
7D36F67A C1B1FC7E 413B181D 9E6E7D2D 257C82FA 34D0169C F84BA90F 7E603AF8
C98F95DD F39715F0 758A21B3 146E067A 2A0C74AB 822DC4DC 555FAE0C 8B170A9A
33505A20 3658B708 C79BD37F B4740E95 0E8677EF A1378B2A 30BC2C8B 965D65C2
04FB0203 010001A3 65306330 0F060355 1D130101 FF040530 030101FF 30100603
551D1104 09300782 05526963 6369301F 0603551D 23041830 16801459 53A66BA5
96B3782C 1E5D01F9 50F6919E 46629E30 1D060355 1D0E0416 04145953 A66BA596
B3782C1E 5D01F950 F6919E46 629E300D 06092A86 4886F70D 01010405 00038181
00351299 2E9318F9 7FD81B19 5AF67D8A 8D8F4327 FCBDEDFC BF045050 A7C7251A
D090948D E167C9CE C359FF60 010343CB 4C286213 7E34236B DD9EDA53 5E35B405
F9F80F68 C0AC8D5A F5BE6E95 474E26D2 C83EFBEB 48784F57 AC742F35 91EB5F6C
0C479E32 239E9166 FB401164 4D257DF1 8002AACE 88E93CCE C0EE0602 D3229707 FE
quit
dot11 syslog
dot11 ssid 180 Beaver
ip source-route
ip cef
ip dhcp excluded-address 10.225.25.1
ip dhcp pool HOME
network 10.225.25.0 255.255.255.240
default-router 10.225.25.1
!no ipv6 cef
voice-card 0
license udi pid UC520W-16U-4FXO-K9 sn FHK114213TB
vtp version 2
bridge irb
interface FastEthernet0/0
ip address dhcp
speed auto
full-duplex
interface Integrated-Service-Engine0/0
ip address 192.168.0.1 255.255.255.0
service-module ip address 192.168.0.254 255.255.255.0
service-module ip default-gateway 192.168.0.1
interface FastEthernet0/1/0
switchport access vlan 2 (Computer plugged into this port)
interface FastEthernet0/1/1
shutdown
interface FastEthernet0/1/2
shutdown
interface FastEthernet0/1/3
shutdown
interface FastEthernet0/1/4
shutdown
interface FastEthernet0/1/5
shutdown
interface FastEthernet0/1/6
shutdown
interface FastEthernet0/1/7
shutdown
interface FastEthernet0/1/8
shutdown
interface Dot11Radio0/5/0
no ip address
ssid 180 Beaver
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
shutdown
bridge-group 1
interface Vlan2
ip address 10.225.25.1 255.255.255.240
interface Vlan3
no ip address
bridge-group 3
interface Vlan4
no ip address
bridge-group 4
interface Vlan5
no ip address
bridge-group 5
interface Vlan6
no ip address
bridge-group 6
interface Vlan7
no ip address
bridge-group 7
interface Vlan8
no ip address
bridge-group 8
interface Vlan9
no ip address
bridge-group 9
interface Vlan10
no ip address
bridge-group 10
interface Vlan11
no ip address
bridge-group 11
interface Vlan12
no ip address
bridge-group 12
interface BVI6
no ip address
interface BVI7
no ip address
interface BVI8
no ip address
interface BVI9
no ip address
interface BVI10
no ip address
interface BVI11
no ip address
interface BVI12
no ip address
ip forward-protocol nd
ip http server
ip http secure-server
logging esm config
control-plane
bridge 1 protocol ieee
bridge 2 protocol ieee
bridge 3 protocol ieee
bridge 4 protocol ieee
bridge 5 protocol ieee
bridge 6 protocol ieee
bridge 7 protocol ieee
bridge 8 protocol ieee
bridge 9 protocol ieee
bridge 10 protocol ieee
bridge 11 protocol ieee
bridge 12 protocol ieee
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
banner login ^CCisco Configuration Assistant. Version: 3.0 (1). Thu May 17 11:45:43 MDT 2012^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
password *******
login
transport input all
End
Router#service-m i0/0 reset
Use reset only to recover from shutdown or failed state
Warning: May lose data on the the NVRAM, nonvolatile file system or unsaved configuration!
Do you want to reset?[confirm]
Trying to reload Service Module Integrated-Service-Engine0/0.
router#
[Resuming connection 1 to 192.168.0.1 ... ]
Cisco BootMon Version: 1Bootmon: reading primary bootloader image
Bootmon: calling bootloader
Cisco ServiceEngine Bootloader Version: 1.0.3
(Jul 6 2007 - 10:15:37) MPC83XX
Resetting devices ....Done.
mac address for internal ethernet 00:1b:8f:ac:89:5e
Please enter '***' to change boot configuration: ***
ServicesEngine Bootloader Version : 1.0.3
ServicesEngine boot-loader> config
IP Address [10.225.25.5] >
Subnet Mask [255.255.255.240] >
TFTP Server [10.225.25.4] >
Gateway [10.225.25.1] >
Default Helper-file [cue-installer.nm-aim.7.0.6] >
Ethernet Interface [internal] [internal] >
Default Boot [none|helper|disk] [disk] >
Default Bootloader [primary|secondary] [primary] >
05-18-2012 09:05 AM
Send relevant config and one can tell what is wrong. Otherwise, it's impossible.
Note: If you are using CCA exclusively, then this is the wrong forum and you must post in "small business voice - UC500". You can move you post using the Actions panel on the right.
05-18-2012 09:15 AM
I'm not using CCA, since CCA can't configure voicemail due to all of the errors, I'm doing all of this on the IOS
05-18-2012 10:19 AM
Here's your problem:
Here's a working config example:
ip address 10.1.1.1 255.255.255.0
ip traffic-export apply test size 2000000
duplex auto
speed auto
ip unnumbered FastEthernet0/0
service-module ip address 10.1.1.2 255.255.255.0
service-module ip default-gateway 10.1.1.1
Then you need to add a route to the ISE:
ip route 10.1.1.2 255.255.255.255 Integrated-Service-Engine0/0
You can use a VLan interface for the IP unnumbered command but I'm not sure it will work if they're on different networks.
First though, just try adding:
ip route 192.168.0.254 255.255.255.255 Integrated-Service-Engine0/0
That might be all you need.
05-18-2012 10:21 AM
Also, all other network devices will need to point to the CME router for network 192.168.0.x.
05-18-2012 11:08 AM
Copied your configuration to a T, can not ping 10.1.1.2, and f0/0 is up
duplex auto
speed auto
05-18-2012 11:15 AM
Where are you trying to ping from? Your pc? You've just introduced a new subnet to your network so make sure your routes are placed accordingly.
Also, what do you get from:
service-module integrated-Service-Engine 0/0 status
05-18-2012 11:19 AM
I'm pinging from the router
Service Module is Cisco Integrated-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module is trying to recover from error
Service Module heartbeat-reset is enabled
Service Module status is not available
Router#ping 10.1.
Trying to reset Service Module Integrated-Service-Engine0/0.
1.2
Sending 5, 100-byte ICMP Echos to 10.1.1.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
05-18-2012 11:22 AM
That's probably the issue right there.
Can you session to it?
Try:
service-module integrated-Service-Engine 0/0 session
05-18-2012 11:24 AM
Yes I can. See my 2nd post, and you'll see the output from when I get into the module.
05-18-2012 12:08 PM
Sorry I missed that. I'm not sure at this point. I'm assuming this was working and now it's stopped? Or is this a new install?
Do you have smartnet?
05-18-2012 12:12 PM
I bought this UC500 used, it has never worked. I have smartnet through my work but I think they'd frown upon me using it for my personal router
05-18-2012 02:19 PM
Got it to work! Basically the service-module IP and bootloader IP address need to be on the same subnet, also I was plugged into a switchport, i moved that over to a fast ethernet port and I could ping from the bootloader module.
Now I have a second issue, when I load the boot helper, it loads, but at the very end it says
##Booting image at 400000 ...
Bad Magic number
The boot helper won't start up for this reason
