I am pretty sure the answer is no, but I cant find a definitive 'no' anywhere. Does the 6945 support Phone proxy?Thanks in Advance,J
We have two seperate MGCP voice gateways for two publishers. Can weconfigure or use one voice gateway for both the publishers for HighAvailability pupose. Regards.
Hi,Does anyone know if Cisco supports Viewmail if the user is running Outlook from Citrix server.Thank you
Ive been looking around in alot of treads and I would like to confirm this: We have Nexvortex as an ITSP and it is obviously voip so its been my understanding when we use CCA to setup the systems we do the dial peer xxxx voip. is this correct? we do ...
Hi Experts,We are planning to use the built in voice recording and monitoring for our agents in Contact Center using UCCX 7.0.2. I know there are certain restrictions with regards to sizing. Is it possble to change the location where the recording ar...
Dear friends,I have a CUCM 8.6.2 with a MGCP gateway connected via interface E1 to the Siemens 300E. The Siemens 300E is connected to a anothers PBX's. My end point is a PBX E&M and the ringback isn't working properly.Calls to another destinations is...
Background:Our UC540 was running 8.2.0 and working with SIP calls through NexVortex using G.729 via CLI commands.We recently upgraded our UC540 to 8.6.0 using CCA 3.2.1, and as soon as we did so, we lost the ability to receive inbound calls. When ...
I'm in need of of some assitance from our friends in the UK. I am familar with the US (NANP) concept of Carrier access Codes, that is 101xxxx. 101 followed by a Carrier Identification Code (CIC) to allow callers to choose another carrier or "dial-a...
Hi,Is it possible to DHCP assign different TFTP server IP addresses for IP phones (ex. 192.168.1.10 CME TFTP for IP Phones and 192.168.1.20 CUCM TFTP for Cius) that are in one subnet? For the moment I created two vlans with dhcp pools, but it would...
Hi,I am looking into configuring intra-site networking between two connection clusters. Do I need an SMTP server (MS Exchange) to be able to establish intra-site link between the unity connection clusters?ThanksJames
HelloI planning an implementation with CUCM Cluster, Right now I have 4 offices with, 2 offices CUCM 4.1 and Unity 4.0, rest 2 CME. Each office has separte PSTN lines and geteways, In the main office We'll have a cluster with IPCC 7.0, but the main d...
I am adding on two subscribers at a remote campus to an existing CUCM cluster that resides at a main campus site. I am also adding on (2) Cisco 3925 routers at the remote campus for inbound/outbound call routing to the PSTN. Using Route List and Ro...
Hi, please assist with this problem adding Trixbox SIP phones to a CME setup.We have had a Cisco UC560 device with 20 phones or so, running fine for a couple of years, connecting to the PSTN via a telco provided SIP trunk. A third party supplier h...
Hi,my aim is to configure speed dialing for my Cisco VoIP phone, automaticly distributing the PIN code for my conference bridge. I know this for smartphone using the comma (,) between dial-number and PIN code. For the cisco phones I didn't find any h...
My 2911 gateway is failing the handshake, and I am trying to figure out the best way to debug it. I turned on all the crypto PKI debugging, but I don't get any information telling me the reason for the failure. Is there any other debugging I can tu...
Subject | Author | Posted |
06-19-2025 08:23 PM | ||
06-17-2025 07:43 AM | ||
06-17-2025 06:11 AM | ||
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
