CUE External VM access
Steellllllllll0
Hi Guys,
I am trying to setup external voicemail access to CUE using one of the PSTN numbers. I have tried different things and currently have a translation rule to match my designated pstn number and replace it with the pilot number. However this is still not working. If i try and test the rule i get a message saying 'rule not defined' but if i do a sh translation-rule X number matched=digits telco is presenting and replaced=my vm pilot number.
Any ideas where i might be going wrong on this ?
slongewa
Can you show me your dial-peers for the designated PSTN number and the Voicemail Pilot?
Steve
Frank Vo
Are you able to post a config for us to take a look at?
Cheers
Frank
