CUEC 9.1 not starting after upgrading cucm 9.1 to 11.5
Question is whether cuec 9.1 is compatible with cucm 11.5?
Best Regards
Your options are to either upgrade to CUACA, use the serverless AC (CUACS) and keep on CUCM 11.5, or as you mention, rollback your CUCM to 9.1 to look into the CUEAC upgrade, and keep it working.
You can find all the documentation on the ACs on cisco.com, the install and configuration guide contains all the info regarding CUCM compatibility.
java
if this helps, please rate
Deepak Rawat
Unfortunately it is not, refer below:
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/Compatibility/CSR-Compatibility-Matrix-InteractiveHTML.html
Deepak
so what you say is I need to roll back my CUCM ver 11.5 to ver 9.1.2 until the customer has changed the CUEAC 9.1?
Best Regards
java
Aseem Anand
From version 10.x onwards CUEAC is not supported. You will have to use advanced version or standard version.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html#pgfId-1166965
Refer to CUEAC guide as well:
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucmac/arc/CUACPERN91120.pdf
Aseem
(Please rate if useful)
