01-31-2011 11:02 PM - edited 03-16-2019 03:11 AM
Hi all,
I am having some issues integrating Cisco Unified Mobility Advantage (CUMA) with MS Active directory.
When completed the Active Directory Advanced Settings configuration and click “Test Config” it comes with the following error, (please also see attched).
Configuration Error Details:
. Search error.
When I search for a user, it doesn’t return any users.
I have verified the Search Base I used is correct and this works fine for CUCM LDAP integration
Admin DN and Admin Password are also correct.
CUMA Version is 7.1.3
MS Active Directory is 2008
CUCM version is 8.0.2
I have checked below link and it says “September 2009” is that mean it is already supported?
Your help on this will be much appreciated
Mohammed
02-01-2011 04:07 PM
Can anyone help with this?
Mohammed
02-02-2011 12:37 AM
Do you use a custom filter in your Active Directoy?
And if possible could you please also attach the snapshot of the User Activation / Deactivation Page?
Rajamani
02-02-2011 01:08 AM
02-02-2011 01:39 AM
Hi Mohammed,
Yes i want to know whether you use Customized Filters in your Active Directory - Domain Controller ? Because if that is the case then we may need to change the search filter
Rajamani
02-02-2011 04:08 PM
Hi Rajamani,
No Customized Filters are used in your Active Directory.
Mohammed
08-08-2011 06:21 AM
Hello Mohammed,
Can you try this filter in the 'Advanced Settings' tab in CUMA and let me know how it goes?
(& (objectClass=user) )
You probably have to restart the CUMA server after making this change.
--Sankar
08-08-2011 06:27 AM
Sorry, the correct format is
(& (objectClass=user))
