03-12-2014 01:54 AM - edited 03-16-2019 10:06 PM
Our existing AD is going to be replaced by latest version of AD,
All information will be same including IP address but just on a different box.
Are there any steps to be performed or how can I check compatibility?
03-12-2014 06:37 AM
Depending on your CUCM version, SRND or system guide has LDAP compatibility.
Assuming it's compatible and you keep all the same info, including userID, nothing really. It will sync as usual
03-12-2014 11:57 AM
Hi Jaime,
Thanks for your reply.
Are you suggesting, that if every information is same.
If we swap old AD with new AD, CUCM will automatically integrate with it.
Regards!
Viren
03-12-2014 06:46 AM
Hello Viren,
Please refere the below compatibility matrix .
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/directry.html#wp1097641
LDAP Directory Type | Cisco Unified CM 6. x | Cisco Unified CM 7. x | Cisco Unified CM 8. x |
Microsoft Active Directory 2000 | Yes | Yes | No longer supported |
Microsoft Active Directory 2003 R1/R2 | R1/R2 supported (32 bit only) | R1/R2 supported (32 bit only) | R1/R2 supported (32 bit only) |
Microsoft Active Directory 2008 R1/R2 | R1 supported (32 bit only) | R1 supported (32 bit only) | R1 supported (32 bit only) |
Microsoft ADAM 2003 R1/R2 | No | R1/R2 supported (32 bit only) | R1/R2 supported (32 bit only) |
Microsoft Active Directory LDS 2008 R1/R2 | No | No | R1 supported |
Netscape 4.x | Yes | No longer supported1 | No longer supported1 |
iPlanet 5.0 | Yes | No longer supported1 | No longer supported1 |
iPlanet 5.1 | Yes | Yes | Yes |
SunOne 5.2 | Yes | Yes | Yes |
SunOne 6.1.x and 6.2.x | Yes | Yes | Yes |
Sun One 6.3.xm | No | Supported with Unified CM 7.1(4) and later releases | Yes |
Sun DS 7.0 | No | Supported with Unified CM 7.1(4) and later releases | Yes |
OpenLDAP 2.3.39 | No | Supported with Unified CM 7.1(2) and later releases | Yes |
OpenLDAP 2.4 | No | Supported with Unified CM 7.1(2) and later releases | Yes |
03-12-2014 12:00 PM
Hi Nadeem,
Regards!
Viren
