Current AD will be replaced by latest version of AD, all info going to be same including IP address, any CUCM precautions?
virender verma
Our existing AD is going to be replaced by latest version of AD,
All information will be same including IP address but just on a different  box.
Are there any steps to be performed or how can I  check compatibility?
Jaime Valencia
Depending on your CUCM version, SRND or system guide has LDAP compatibility.
Assuming it's compatible and you keep all the same info, including userID, nothing really. It will sync as usual
java
if this helps, please rate
Hi Jaime,
Thanks for your reply.
Are you suggesting, that if every information is same.
If we swap old AD with new AD, CUCM will automatically integrate with it.
Regards!
Viren
Nadeem Ahmed
Hello Viren,
Please refere the below compatibility matrix .
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/directry.html#wp1097641
LDAP Directory Type
Cisco Unified CM 6. x
Cisco Unified CM 7. x
Cisco Unified CM 8. x
Microsoft Active Directory 2000
Yes
Yes
No longer supported
Microsoft Active Directory 2003 R1/R2
R1/R2 supported (32 bit only)
Microsoft Active Directory 2008 R1/R2
R1 supported (32 bit only)
Microsoft ADAM 2003 R1/R2
No
Microsoft Active Directory LDS 2008 R1/R2
No
No
R1 supported
Netscape 4.x
Yes
No longer supported1
iPlanet 5.0
Yes
iPlanet 5.1
Yes
Yes
Yes
SunOne 5.2
Yes
Yes
Yes
SunOne 6.1.x and 6.2.x
Yes
Yes
Yes
Sun One 6.3.xm
No
Supported with Unified CM 7.1(4) and later releases
Yes
Sun DS 7.0
No
Yes
OpenLDAP 2.3.39
No
Supported with Unified CM 7.1(2) and later releases
Yes
OpenLDAP 2.4
No
Yes
Br, Nadeem Please rate all useful post.
Hi Nadeem,
Regards!
Viren
