08-10-2012 06:53 AM - edited 03-16-2019 12:38 PM
Hello everyone,
I need to clarify some doubts:
Using the CUWL STD licensing level can i use Jabber Mobile Voice Client? Or do i really need to use CUWL PRO?
The main idea is to use the mobile clients over a Wi-Fi network to creat a extension line mobility environment, so even away from its desk, his celphone would carry its personal extension number.
Solved! Go to Solution.
08-10-2012 07:11 AM
08-10-2012 07:11 AM
You need PRO.
Chris
08-10-2012 07:20 AM
Hi Bruno,
Chris is most correct here (as usual )
Cisco Unified Workspace Licensing is available in three versions:
http://www.cisco.com/en/US/products/ps9156/index.html
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
08-10-2012 07:31 AM
Thank you guys!
I did not know that there is a Premium Edition (CUCM 9.0??), i know that before there was an ENTRY but it's not used anymore...
Anyway we will need to stick with the CUWL PRO.
08-10-2012 07:33 AM
Hi Bruno,
This CUCM 9.x doc has a good chart with the feature sets
Cheers!
Rob
08-10-2012 07:41 AM
Cool, it would be great to use the Premium edition ($80 cheaper) but i think it's not available on the moment, as it does not shows up in CCW.
