10-11-2011 10:37 AM - edited 03-16-2019 07:26 AM
CX 8.5(1)SU1
RPSM -
Connection Refused by Remote Server...
However my IP is in the whitelist, last version from Cisco Unity Tools.
I've been using the Remote Port Status Monitor for several days, however now myself and 2 other users are getting Connection Refused by Remote Server, is there a Connection Service I can restart to fix the Remote Port Status Montior?
10-11-2011 10:44 AM
Hi Jason,
It's probably the database proxy service
The path is as follows;
Unity Connection Serviceability > Tools > Service Management > Select Server > Optional Services >Connection Database Proxy > Activate/Start
You also need to set the
Unity Connection Administration > Advanced > Connection Administration >
Cheers!
Rob
10-11-2011 12:57 PM
Everything was setup properly, Database Proxy Service showed started. I restarted the Database Proxy Service and was able to re-connect.
04-13-2017 08:30 AM
Thanks Rob, oldie but goodie...worked
