CXN 8.5SU1 Remote Port Status Monitor in whitelist not connecting
Jason Aarons
Level 6
Level 6
CX 8.5(1)SU1
RPSM -
Connection Refused by Remote Server...
However my IP is in the whitelist, last version from Cisco Unity Tools.
I've been using the Remote Port Status Monitor for several days, however now myself and 2 other users are getting Connection Refused by Remote Server, is there a Connection Service I can restart to fix the Remote Port Status Montior?
Rob Huffman
Hi Jason,
It's probably the database proxy service
The path is as follows;
Unity Connection Serviceability > Tools > Service Management > Select Server > Optional Services >Connection Database Proxy > Activate/Start
You also need to set the
Unity Connection Administration > Advanced > Connection Administration >
Cheers!
Rob
Everything was setup properly, Database Proxy Service showed started.  I restarted the Database Proxy Service and was able to re-connect.
Thanks Rob, oldie but goodie...worked
