Debug CCSIP shows no output
tknapp
         Running "debug ccsip all" and seeing no output.  Other debugs show output (debug ip icmp).
Code is:
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVIPSERVICESK9-M), Version 15.2(4)S1, RELEASE SOFTWARE (fc3)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sat 06-Oct-12 11:55 by mcpre
Technical Support: http://www.cisco.com/techsuppo
The uknit is a ASR1002.  SIP Calls are going through the gateway and SIP is functioining.  Trying to get the debugs to work.
I see another person had same issue but fixed it with "credentials"  I see no mention of this variable in documentation that I can find.
All help will be appreciated Thanks
7 Replies 7
Hi.
Configure logging on your router
logging buffered 4096
logging monitor debug
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Thank you for suggestion.
I have made changes and still no CCSIP debugs.
As stated all other debugs tested do show up in log and to screen (term mon).
Hi Have you also tried with debug ccsip messages instead of debug ccsip all?
Let me know
Carlo
Yes I picked individual debug CCSIP commands and have same issue.  NO output.
Thank you
Let's say you have configuration as follows:
logging buffered 20000000
no logging console
no logging monitor
Can you run #term mon and then #debug ccsip messages to view the debug messages?
Or first logging monitor debug command must be entered in the global configuration.
Thank you.
If you have the configuration command "no logging monitor" then you won't see anything on an SSH session, even with the "term mon" command.
Can you please attach your actual configuration?
Carlo
