Hi Experts,
I want debug isdn messages by a specified DNIS, anyone knows this command?
I just found VG can debug isdn message by E1 ports.
Thanks in advance,
Solved! Go to Solution.
Qazzaq,
If your IOS supports you can use per call debugging feature on the gateway
conf t
call filter match-list 1 voice
incoming calling-number XXXXX (or)
outgoing called-number XXXXXX (or )
incoming called-number XXXXX
then in exec mode
#debug condition match-list 1
Now run your debug isdn q931 debug
## debug isdn q931
No you cant do that the debug isdn q931 does not let you further specify based on DNIS,
you would need to capture the output in a log file and open it in something like notepad ++
Please rate if useful
Thanks for your reply, Dennis... But it's really hard if i want to trace a specific call, in my environment, VG 3945 connect 16 E1 and cps can almost reach 50 at peak hour...
Qazzaq,
conf t
then in exec mode
## debug isdn q931
