debug isdn no output
Mary
I have one issue, when I debug isdn q931 on branch voice gateway, it says no resource available, what's the root cause and how to resolve it?
I debug in headquarter voice gateway, there is no output, what's the root cause? thanks
8 Replies 8
Your memory usage most likely is very high. Check it using show mem
command.
memory is normal and cpu utilization also normal
mem and cpu utiliz normal
Use CLI Analyzer to interpret the output of your show tech. It will
pinpoint resource problems.
https://cway.cisco.com/go/sa/
Aadhil Salim
please share debug isdn q931 screen shot
Georgios Fotiadis
Can you describe the exact call flow and attach the output of debug isdn q931 and debug voip ccapi inout.
Georgios
Please rate if you find this helpful.
this is still under investigation
what is the output of "show isdn status", Also have you already tried everything else recommended on this thread?
Aeby
Aeby
