Debug voip commands for routers
ERRIN MILLER
I have an ISDN gateway interfacing with a PBX.  I have the Calling Search Space set in UCM 8 so it matches with all of my other gateways (abotu 40 others).  The end user on the PBX dials 8-XXX-XXXX, and the PBX is supposed to send the call to the router with digits XXX-XXXX.
At my problem site, If the end user calls 8-350-9999 it works.  the only pattern that does not work is 8-8XX-XXXX.  They are getting a fast busy back.  I tried to run a debug.  I was using debug voip ccapi inout.  I could see it capturing information on all calls, except the rejected calls.  Is there a good debug to capture the attempt?  I think the PBX may be sending 8-8XX-XXXX instead of 8XX-XXXX.  Thanks.
tobin hawkshaw
debug isdn q931 is your friend.
tobin hawkshaw
