Debug voip rtp
gnanavel.ns
Can someone share (if available) the documentation for the debug command 'debug voip rtp' ? Facing an issue with inbound voice call from gateway. Once the user picks up the extension, its only blank and the call disconnects after a few secs. The destination is Avaya CM 3.x. There is no issue for outbound calls. The output of 'debug voip rtp' for the inbound call and outbound apparently seem to be same.
If we can interpret the debug output in a correct way, it might help troubleshooting.
Gnanavel.
paolo bevilacqua
That debug is not needed. Case like your are usually due to codec mismatch, and can be troubleshoot with other debugs.
