dependency records
reidg
starting to feel like an idiot here, I'm trying to view dependency records, as i'm tryng to delete a CSS but its in use.
I've turned dependency on, but can't find where to view then, the help say's go to the related items box on the cucm config page and select dependency records. However I can't find this related items box anywhere, i'm obviously missing it, so can someone tell me where it is please, thanks
Grant
go into the CSS, partition, whatever.
then, on the right hand just above the icons (new, delete, etc) and below the main menu there is a line. There is a dropdown menu there, usually it would say go back to find/list, go back to device page, depending on what you're looking for. just click on the drop-down menu, select dependency records and click the GO button
java
if this helps, please rate
java
Steffen.Baier
What Version of Call Manager are you using ?
Steffen
6.1 Steffen
java
java
aarrgghh, new I'd saw it somewhere, thanks for that.
