03-19-2009 07:45 AM - edited 03-15-2019 04:57 PM
Dears,
i am trying to deply transcoders on two cme routers, to permit the forwarding of unanswered or busy lines to voicemail. On the voip dial-peers between the branches i am using a g729 codec.
So i configured transcoders on both routers and i verified that the transcoders are registered to the CME routers but it seems that any call from the other branch is still forwarded to the unity express without being transcoded to g711. The following is the transcoder config on the first router:
voice-card 0
dsp services dspfarm
sccp local GigabitEthernet0/0
sccp ccm 192.168.101.50 identifier 1 version 3.1
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register mtp001bd4ee70a0
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
maximum sessions 2
associate application SCCP
dial-peer voice 100 voip
destination-pattern 6..
session protocol sipv2
session target ipv4:192.168.101.51
dtmf-relay sip-notify rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
no vad
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 10
sdspfarm tag 1 mtp001bd4ee70a0
sh sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
IPv4 Address: 192.168.101.50
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.101.50, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
Trustpoint: N/A
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.101.50, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 4, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
sh sdspfarm units
mtp-1 Device:mtp001bd4ee70a0 TCP socket:[1] REGISTERED in SCCP ver 0/10
actual_stream:4 max_stream 4 IP:192.168.101.50 64050 MTP YOKO keepalive 237
Supported codec:
G711Ulaw
G711Alaw
G729
G729a
G729b
G729ab
max-mtps:1, max-streams:20, alloc-streams:4, act-streams:0
Can anyone help plz?
Best regards
03-19-2009 10:01 AM
This is my working config.
voice-card 1
dspfarm
sccp local Vlan110
sccp ccm 171.X.X.225 identifier 1
sccp
sccp ccm group 1
associate profile 2 register MTP123456789123
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
maximum sessions 1
MK
