device css and line css
kp-tkr2014
I have  the below  settings
RP  9.00! . partition international1
RP  9.00! . partition international2
css_int1
international1
css_int2
international2
one is going through the  trunk1  and another going through the trunk2
if I assign first css on line and second one on device css , what will happen if user  dials the pattern
HARIS_HUSSAIN
1) Line CSS will have preference over Device CSS whenever there are exact same Patterns in Two CSS.In You case css_int1 ie trunk1 will be used.
I recommend more reading here
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_5_1/ccmsys/accm-851-cm/a03ptcss.pdf
If you configure a calling search space both on an IP phone line and on the device (IP phone) itself, Cisco
Unified Communications Manager concatenates the two calling search spaces and places the line calling
search space in front of the device calling search space. If the same route pattern appears in two
partitions, one contained in the line calling search space and one contained in the device calling search
space, Cisco Unified Communications Manager selects the route pattern that is listed first in the
concatenated list of partitions (in this case, the route pattern that is associated with the line calling search
space).
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
