03-04-2019 02:19 PM
Is there a way to set the line recoding options as a default somewhere on CUCM 11.5?
Diego
Solved! Go to Solution.
03-05-2019 03:56 AM
1) You can use the BAT Tool to set the Line recording option for multiple phones.
2) Or you can use Universal Device Template and use it while creating any new Devices to Enable Recording on the same.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
03-05-2019 03:56 AM
Haris
03-05-2019 08:08 PM
Looks like the UDT is what I am looking for.
Thank you!
