Device Mobility groups and CUCM 4.2 and CUCM 10.5
aalejo
Level 5
Level 5
Dear Community:
On CCO said that on version CUCM 4.2 device-level setting get overwrite by Roaming Sensitive Settings when roaming on the same or different DMG  but on on version 10.5 said that device-pool level setting are the ones that get overwrite.
Which one is true?
- Alex
Manish Gogna
Hi Alex,
For CUCM 10.x
The parameters under these settings will override the device-level settings when the device is roaming within or outside a Device Mobility Group. The parameters included in these settings are:
  • Date/time Group
  • Region
  • Media Resource Group List
  • Location
  • Network Locale
  • SRST Reference
  • Physical Location
  • Device Mobility Group
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/mobilapp.html#pgfId-1239811
For CUCM 4.x
Date/time Group
Region
Location
Network Locale
SRST Reference
Physical Location
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/4x/42dvmobl.html
I do not see any discrepancy there.
Manish
Look at this document:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsgd-861-cm/fsdevmob.html
It said:
For roaming devices, Cisco Unified Communications Manager overwrites the following device pool parameters with the device pool settings for the subnet:
Date/Time Group
Region
Location
Network Locale
SRST Reference
Connection Monitor Duration
Physical Location
For example some of those parameters like "Device Mobility Group" are at the pool level and not at the device level.
They can not be overwrite at the device level...
- Alex
