02-01-2019 04:02 PM - edited 03-17-2019 02:03 PM
I am trying to generate a report to see device usage over the last year.
For example, I have a location with 20 Cisco 8821s. I am trying to see if there was any point during the last year, that all 20 of those devices were in use. Any help is greatly appreciated.
This is my first post and I am new to the voice world so please go easy.
02-01-2019 04:12 PM - edited 02-01-2019 04:12 PM
Dont have monuitoring system in place to monitor these device provide information all over the time.
If not you need to setup one, using MRTG/PRTG/solarwinds to get stastics.
02-01-2019 04:19 PM
So I take it from your reply, there is nothing in CallManager or another tool offered by Cisco that could generate the type of report I'm looking for is that correct?
02-01-2019 04:23 PM
There is 2 things we are discussing here.
1. i was mentioned about Device report availbility. - Like device up or down.
2. I believe you are looking CDR (call detail records ) is this correct ?
02-01-2019 04:30 PM
What I am wanting to see is the maximum amount out of the 20 devices that were actively used over the last year.
Example:
They are wanting to add additional phones. To justify this request, I am wanting to see the highest usage of these 20 phones. Was there ever a period of time over the last year that all 20 of these phones were connected and making calls? Or was the highest 12?
I hope this helps with clarification.
02-01-2019 04:39 PM
So you looking phone usage report (CDR) - How is your setup.
Where these 20 devices are connecting ? CME or CUCM ? explain more. so i can point to right direction you can get the reports. if you have one enabled in the Call Manager.
02-01-2019 04:41 PM
02-01-2019 04:43 PM
I managed to find the CDR reports in Serviceability. Let me give that a shot and see what I can find.
Thank you both for your help.
02-01-2019 04:51 PM
yes you can select the range for taht device and generate report it will produce the call volumen.
02-01-2019 05:58 PM
There is no way to get a year's worth of information, assuming you changed the retention period to the maximum, that's 180 days. And that's only if you don't hit the high watermark in the DB and data has to be overwritten before 180 days.
Best case scenario, you'll get 6 months worth of data.
You could only get that period of time using a 3rd party billing server where you kept the CDRs for that long.
02-11-2019 05:40 AM
