dial out of voicemail - callmanager 7
svorenstein
Hi everyone,
Is there a way to configure an option from someones voicemail recording to dial out if 1 is pushed?  So if someone records in the voicemail message to dial 1 to connect to a cell number, it will cancel the recording and dial out to that number?
Any help is appreciated...thanks.
Assuming you're using Unity Conncetion, you should be able to set that up under Caller input in the user's mailbox.   Select "Call Action", "Transfer to Alternate Contact Number" and enter the number you want to call out to (make sure you include any external access and LD codes (9, 91, etc)   You need to make sure your transfer rules in UCCXN support this dialing and your voicemail ports need to have the correct CSS to support outbound dialing.
Glenn
