Dial peer not matching called number
iverson.justin
I have these 4 dial peers and trying to get specific numbers to take a different peer but number keeps getting matched with wild card peers, 4002 and 5000. Instead of the more specific e164 peers 80057 & 800.
Example:
dial-peer voice 4002 voip
rtp payload-type comfort-noise 13
session protocol sipv2
incoming uri via pstn
voice-class codec 1
voice-class sip early-offer forced
voice-class sip tenant 900
dtmf-relay rtp-nte
no vad
dial-peer voice 5000 voip
description outbound to CUCM
destination-pattern +...........$
session server-group 100
voice-class codec 1
voice-class sip tenant 500
dtmf-relay sip-kpml rtp-nte
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
dial-peer voice 80057 voip
no modem passthrough
destination e164-pattern-map 100
voice-class codec 2 offer-all
voice-class sip pass-thru content sdp
dtmf-relay rtp-nte
fax-relay ecm disable
fax-relay sg3-to-g3
fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback pass-through g711ulaw
no vad
dial-peer voice 800 voip
incoming called e164-pattern-map 100
dtmf-relay rtp-nte
fax-relay sg3-to-g3
no vad
The gateway moves on to the next criteria only if no match is found. Apparently destination-pattern has higher preference than e164-pattern-map.
Table 4. Outbound SIP Dial-Peer Selection Preference
Preference
Match Criteria
Dial-peer Commands
Dial-Peer Group Dial-Peer
destination dpg <dpg-tag>
(DPG configured on inbound dial-peer)
Dial-Peer Provision Policy URI
destination uri-from <uri-tag>
destination uri-to <uri-tag>
destination uri-via <uri-tag>
destination uri-diversion <uri-tag>
destination uri-referred-by <uri-tag>
(DPP configured on inbound dial-peer)
ILS Route String
destination route-string <route-string-tag>
URI and Carrier-ID
destination uri <uri-tag> AND carrier-id target <string>
Called Number and Carrier-ID
destination-pattern <number-string> AND carrier-id target <string>
6
URI
7
Called Number
destination-pattern <DNIS-number>
destination e164-pattern-map <pattern-map-number>
dnis-map <dnis-map-number>
8
Calling Number
destination calling e164-pattern-map <pattern-map-number>
Response Signature
