10-17-2016 05:15 AM - edited 03-17-2019 08:22 AM
What is wrong with this Inbound Dial Peer? It doesnt seem to match. I have even replaced it with the exact DNIS being sent from our Freeswitch box to the gateway and it still doesnt match. Our Freeswitch box prefixes the digits. The freeswitch box is added to the Toll Fraud allowed list.
10.21.10.250 is the GW
10.21.10.12 is the Freeswitch
dial-peer voice 201 voip
description INBOUND from FS
session protocol sipv2
incoming called-number 3336+1112223333
codec g711ulaw
VoiceGW#
*Oct 17 11:38:01.149: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:3336+1112223333@10.21.10.250 SIP/2.0
Via: SIP/2.0/UDP 10.21.10.12:5080;rport;branch=z9hG4bKNagctFetZeByp
Max-Forwards: 69
From: "1001" <sip:FreeSWITCH@10.21.10.250>;tag=Na3U2yrHgryKr
To: <sip:3336+1112223333@10.21.10.250>
Call-ID: b328f4cb-0f04-1235-41bf-005056820b2e
CSeq: 98016871 INVITE
Contact: <sip:gw+f170dc57-cdf4-4115-933c-7c9b5d4e1fed@10.21.10.12:5080;transport=udp;gw=f170dc57-cdf4-4115-933c-7c9b5d4e1fed>
User-Agent: FreeSWITCH
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REGISTER, REFER, NOTIFY
Supported: timer, path, replaces
Allow-Events: talk, hold, conference, refer
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 289
X-accountcode: 10.21.10.12
X-FS-Support: update_display,send_info
Remote-Party-ID: "1001" <sip:13053284888@10.21.10.250>;party=calling;screen=yes;privacy=off
v=0
o=FreeSWITCH 1476674500 1476674501 IN IP4 10.21.10.12
s=FreeSWITCH
c=IN IP4 10.21.10.12
t=0 0
m=audio 31370 RTP/AVP 0 8 3 101 13
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
*Oct 17 11:38:01.153: //-1/FE40F48D842D/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=13053284888
----- ccCallInfo IE subfields -----
cisco-ani=13053284888
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=3336+1112223333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Oct 17 11:38:01.153: //-1/FE40F48D842D/CCAPI/cc_api_call_setup_ind_common:
Interface=0x23036E14, Call Info(
Calling Number=13053284888,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=3336+1112223333(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=3787
*Oct 17 11:38:01.153: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
10-17-2016 05:40 AM
Hi Joli,
If you check the Ivite INVITE sip:3336+1112223333@10.21.10.250 SIP/2.0
3336 is not prefixed where as it is with and operator.
Also when you give the + in the string with Incoming-called number it is taken as attribute.
Do could you send it correct CLID.
10-17-2016 06:25 AM
OK so how can I fix this. This is what Freeswitch sends to the GW. All calls are prefixed that way. Calls are sent out of Freeswitch in E.164 Format.
I could have it generic dial-peer to match everything, but the issue is that we will have different boxes connected to the GW with different prefixes
I have changed it to
incoming called-number 3336T
and it still doesnt work.
I ultimately need to match the dial-peer strip the 3336 and send it out to the carrier.
thanks,
10-17-2016 06:30 AM
Hi Joli,
I am not aware as to how your rest of the calls are working but you can create a dial-peer with incoming called number . and use translation profiles to strip the prefixes:
Rule 1 can be for 3336 and for example if for other calls you are getting 4446 then you can strip it in rule 2.
voice translation-rule 1
rule 1 /^3336\(.*\)/ /\1/
rule 2 /^4446\(.*\)/ /\1/
Voice translation profile incoming
translate called 1
Aseem
(Please rate if useful)
10-17-2016 07:27 AM
This is what I have and it doesnt seem to be working. When I do
test voice transtation-rule 21 3336*1234568 it works, but it doesnt work on the dial peer correctly. The 3336 does not get stripped.
voice translation-rule 21
voice translation-profile FromHomeFS
translate called 21
translation-profile incoming FromHomeFS
incoming called-number .T
codec g711ulaw
10-17-2016 09:15 AM
3336+ means 6 is repeated on or more time.
http://docwiki.cisco.com/wiki/Cisco_IOS_Voice_Troubleshooting_and_Monitoring_--_Voice_Call_Debug_Filtering_on_Cisco_Voice_Gateways#Table:_Number_Matching_Examples_Using_Wildcard_Symbols
Try Escape character 3336\+1112223333.
