06-27-2013 04:52 AM - edited 03-16-2019 06:06 PM
Hi Guys,
I have Vg224 using sccp registered to cucm ,in srst mode i had to create dial-peer with destination pattern to match the number of the fxs port .
Now after cucm returns online the router uses the dial peers with less preference over the dial peer that under stcapp.
when using debug voip dialpeer this obviously show that it matches the less preferenced dial-peer and i can understand the reason that it matched the ANI with destination pattern,but i can't use the in coming called number while the dialpeer is under the stcapp so how to overcome this behaviour ? i changed the dial-peer hunt to use preference first but as i understand if the incoming dialpeer doesnot send the call to call manager then it doesnot matter.
Here is a sample config:
dial-peer voice 20 pots
preference 1
service stcapp
fax rate disable
port 2/0
dial-peer voice 120 pots
description USED IN SRST
preference 2
destination-pattern 101
port 2/0
How to make the calls go to cucm first ?
Help plz.
06-27-2013 05:19 AM
VG224 SCCP ports can register with SRST GW and there should be no need to add any specific dial-peers, they will work fine with them if your DP assigned to the ports has proper SRST reference and if the SCCP group on the VG224 lists the SRST GW as the last CUCM.
HTH,
Chris
06-27-2013 05:25 AM
Hi Chris,
what do you mean by ( DP assigned to the ports has proper SRST reference ),how to add the srst reference under the dial peer assigned to the ports ?
(and if the SCCP group on the VG224 lists the SRST GW as the last CUCM.)
i have this configured.
06-27-2013 05:28 AM
You do this in CUCM, the device pool assigned to the SCCP ports on CUCM have a device pool with SRST reference assigned to it. Then as long as the SCCP group on the VG224 references the SRST as CUCM the phones register natively with SRST and you have no need for any additional dial-peers, etc.
HTH,
Chris
06-27-2013 05:29 AM
i have this in place too.ok i will remove the additional dial peers and update you now.
06-27-2013 05:48 AM
Now i receive a fast busy tone on the fxs ports after removing the dial peers .
Here are the config:
stcapp ccm-group 1
stcapp
stcapp feature access-code
prefix #
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
modem passthrough nse codec g711alaw
application
global
service alternate Default
not all the ports next :
interface FastEthernet0/0
ip address 192.168.91.210 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 192.168.91.251
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.91.251
ip http server
control-plane
voice-port 2/0
cptone RU
timeouts initial 15
timeouts interdigit 5
timeouts call-disconnect 0
timeouts ringing infinity
station-id number 101
caller-id enable
voice-port 2/1
cptone RU
timeouts initial 15
station-id number 102
caller-id enable
voice-port 2/2
cptone RU
timeouts initial 15
station-id number 103
caller-id enable
sccp local FastEthernet0/0
sccp ccm 192.168.91.7 identifier 2 priority 2 version 4.1
sccp ccm 192.168.91.8 identifier 1 priority 1 version 4.1
sccp ccm 192.168.91.251 identifier 3 priority 3 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
switchback method graceful
service stcapp
fax rate disable
port 2/0
dial-peer voice 21 pots
service stcapp
fax rate disable
port 2/1
dial-peer voice 22 pots
service stcapp
fax rate disable
port 2/2
dial-peer voice 23 pots
service stcapp
fax rate disable
port 2/3
dial-peer voice 24 pots
service stcapp
fax rate disable
port 2/4
dial-peer voice 25 pots
service stcapp
fax rate disable
port 2/5
dial-peer voice 26 pots
service stcapp
fax rate disable
port 2/6
dial-peer voice 27 pots
preference 1
service stcapp
fax rate disable
port 2/7
dial-peer voice 28 pots
service stcapp
fax rate disable
port 2/8
dial-peer voice 29 pots
service stcapp
fax rate disable
port 2/9
dial-peer voice 210 pots
service stcapp
fax rate disable
port 2/10
dial-peer voice 212 pots
service stcapp
fax rate disable
port 2/12
dial-peer voice 213 pots
service stcapp
fax rate disable
port 2/13
dial-peer voice 214 pots
service stcapp
fax rate disable
port 2/14
dial-peer voice 215 pots
service stcapp
fax rate disable
port 2/15
dial-peer voice 216 pots
service stcapp
fax rate disable
port 2/16
dial-peer voice 217 pots
service stcapp
fax rate disable
port 2/17
dial-peer voice 218 pots
service stcapp
fax rate disable
port 2/18
dial-peer voice 219 pots
service stcapp
fax rate disable
port 2/19
dial-peer voice 220 pots
service stcapp
fax rate disable
port 2/20
dial-peer voice 221 pots
service stcapp
fax rate disable
port 2/21
dial-peer voice 88888 voip
destination-pattern 9T
session target ipv4:192.168.91.251
VG224#show dial-peer voice summary
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT
20 pots up up 0 down 2/0
21 pots up up 0 down 2/1
22 pots up up 0 down 2/2
23 pots up up 0 down 2/3
24 pots up up 0 down 2/4
25 pots up up 0 down 2/5
26 pots up up 0 down 2/6
27 pots up up 1 down 2/7
28 pots up up 0 down 2/8
29 pots up up 0 down 2/9
210 pots up up 0 down 2/10
212 pots up up 0 down 2/12
213 pots up up 0 down 2/13
214 pots up up 0 down 2/14
215 pots up up 0 down 2/15
216 pots up up 0 down 2/16
217 pots up up 0 down 2/17
218 pots up up 0 down 2/18
219 pots up up 0 down 2/19
220 pots up up 0 down 2/20
221 pots up up 0 down 2/21
222 pots up up 0 down 2/22
223 pots up up 0 down 2/23
211 pots up up 0 down 2/11
88888 voip up up 9T 0 syst ipv4:192.168.91.251
VG224#
SCCP Admin State: UP
Gateway IP Address: 192.168.91.210, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.91.7, Port Number: 2000
Priority: 2, Version: 4.1, Identifier: 2
Call Manager: 192.168.91.8, Port Number: 2000
Priority: 1, Version: 4.1, Identifier: 1
Call Manager: 192.168.91.251, Port Number: 2000
Priority: 3, Version: 4.1, Identifier: 3
Alg_Phone Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.91.251, Port Number: 2000
TCP Link Status: CONNECTED, Device Name: AN940F4FF5B8400
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
Supported Codec: g729r8, Maximum Packetization Period: 220
Supported Codec: NSE VBD, Maximum Packetization Period: 20
VG224#show stcapp dev
VG224#show stcapp device s
VG224#show stcapp device summary
Total Devices: 24
Total Calls in Progress: 0
Total Call Legs in Use: 0
Port Device Device Call Dev Directory Dev
Identifier Name State State Type Number Cntl
2/0 AN940F4FF5B8400 INIT UNREGISTERED ALG 101 UNKN
2/1 AN940F4FF5B8401 INIT UNREGISTERED ALG 102 UNKN
2/2 AN940F4FF5B8402 INIT UNREGISTERED ALG 103 UNKN
2/3 AN940F4FF5B8403 INIT UNREGISTERED ALG 104 UNKN
2/4 AN940F4FF5B8404 INIT UNREGISTERED ALG 105 UNKN
2/5 AN940F4FF5B8405 INIT UNREGISTERED ALG 109 UNKN
2/6 AN940F4FF5B8406 INIT UNREGISTERED ALG 110 UNKN
2/7 AN940F4FF5B8407 INIT UNREGISTERED ALG 111 UNKN
2/8 AN940F4FF5B8408 INIT UNREGISTERED ALG 112 UNKN
2/9 AN940F4FF5B8409 INIT UNREGISTERED ALG 113 UNKN
2/10 AN940F4FF5B840A INIT UNREGISTERED ALG 114 UNKN
2/11 AN940F4FF5B840B INIT UNREGISTERED ALG 115 UNKN
2/12 AN940F4FF5B840C INIT UNREGISTERED ALG 118 UNKN
2/13 AN940F4FF5B840D INIT UNREGISTERED ALG 119 UNKN
2/14 AN940F4FF5B840E INIT UNREGISTERED ALG 120 UNKN
2/15 AN940F4FF5B840F INIT UNREGISTERED ALG 121 UNKN
2/16 AN940F4FF5B8410 INIT UNREGISTERED ALG 122 UNKN
2/17 AN940F4FF5B8411 INIT UNREGISTERED ALG 123 UNKN
2/18 AN940F4FF5B8412 INIT UNREGISTERED ALG 128 UNKN
2/19 AN940F4FF5B8413 INIT UNREGISTERED ALG 132 UNKN
2/20 AN940F4FF5B8414 INIT UNREGISTERED ALG 133 UNKN
2/21 AN940F4FF5B8415 INIT UNREGISTERED ALG 134 UNKN
2/22 AN940F4FF5B8416 INIT UNREGISTERED ALG 135 UNKN
2/23 AN940F4FF5B8417 INIT UNREGISTERED ALG 136 UNKN
06-27-2013 05:53 AM
Are the ports registered with the SRST GW?
Chris
06-27-2013 06:02 AM
before i deleted the dialpeers they was getting dial tone but also after using the station-id number command under the voice port
On the srst gateway.
2901#show ephone summary
hairpin_block:
ephone-1[0] Mac:0004.F2F5.0C29 TCP socket:[1] activeLine:0 whisperLine:0 REGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0
IP:192.168.92.14 * 7937 keepalive 52 music 0 1:1 CM Fallback
ephone-2[1] Mac:6886.A7C5.6E09 TCP socket:[3] activeLine:0 whisperLine:0 REGISTERED
IP:192.168.92.18 * 7975 keepalive 43 music 0 1:2 CM Fallback
ephone-3[2] Mac:F029.29E3.A54A TCP socket:[2] activeLine:0 whisperLine:0 REGISTERED
IP:192.168.92.16 * 7962 keepalive 43 music 0 1:3 CM Fallback
ephone-4[3] Mac:F029.29E3.31E1 TCP socket:[28] activeLine:0 whisperLine:0 REGISTERED
IP:192.168.92.17 * 7962 keepalive 40 music 0 1:4 CM Fallback
ephone-5[4] Mac:40F4.FF5B.8400 TCP socket:[4] activeLine:0 whisperLine:0 REGISTERED
IP:192.168.91.210 * SCCP Gateway (AN) keepalive 42 music 0
port 2/0/0
ephone-6[5] Mac:40F4.FF5B.8401 TCP socket:[5] activeLine:0 whisperLine:0 REGISTERED
port 2/0/1
ephone-7[6] Mac:40F4.FF5B.8402 TCP socket:[6] activeLine:0 whisperLine:0 REGISTERED
port 2/0/2
ephone-8[7] Mac:40F4.FF5B.8403 TCP socket:[7] activeLine:0 whisperLine:0 REGISTERED
port 2/0/3
06-27-2013 06:05 AM
Your PSTN GW should have the normal dial-peers, are you dialing proper digits?
Can you post "debug voice dialpeer" from your PSTN GW and provide the config of that GW.
Chris
06-27-2013 06:13 AM
Chris,i get fast busy signal when the analog phone goes off hook.the debug voip dial peer shows nothing on the gateway
and on the vg224 i get the match of the incoming dialpeer but further digits are not processed cause of the fast busy directly after phone goes off hook.
06-27-2013 06:18 AM
Can you post your current VG224 config?
06-27-2013 06:27 AM
ip subnet-zero
no ip dhcp use vrf connected
stcapp ccm-group 1
stcapp
prefix #
voice-card 0
voice service voip
application
global
username admin privilege 15 secret 5 XXXXXX
archive
log config
logging enable
notify syslog
hidekeys
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip classless
ip http server
control-plane
voice-port 2/0
cptone RU
timeouts initial 15
caller-id enable
voice-port 2/1
cptone RU
timeouts initial 15
caller-id enable
voice-port 2/2
cptone RU
timeouts initial 15
caller-id enable
voice-port 2/3
cptone RU
timeouts initial 15
station-id number 104
caller-id enable
voice-port 2/4
cptone RU
timeouts initial 15
station-id number 105
caller-id enable
voice-port 2/5
cptone RU
timeouts initial 15
station-id number 109
caller-id enable
voice-port 2/6
cptone RU
timeouts initial 15
station-id number 110
caller-id enable
voice-port 2/7
cptone RU
timeouts initial 15
station-id number 111
caller-id enable
voice-port 2/8
cptone RU
timeouts initial 15
station-id number 112
caller-id enable
voice-port 2/9
cptone RU
timeouts initial 15
station-id number 113
caller-id enable
voice-port 2/10
cptone RU
timeouts initial 15
station-id number 114
caller-id enable
voice-port 2/11
cptone RU
timeouts initial 15
station-id number 115
caller-id enable
voice-port 2/12
cptone RU
timeouts initial 15
station-id number 118
caller-id enable
voice-port 2/13
cptone RU
timeouts initial 15
station-id number 119
caller-id enable
voice-port 2/14
cptone RU
timeouts initial 15
station-id number 120
caller-id enable
voice-port 2/15
cptone RU
timeouts initial 15
station-id number 121
caller-id enable
voice-port 2/16
cptone RU
timeouts initial 15
station-id number 122
caller-id enable
voice-port 2/17
cptone RU
timeouts initial 15
station-id number 123
caller-id enable
voice-port 2/18
cptone RU
timeouts initial 15
station-id number 128
caller-id enable
voice-port 2/19
cptone RU
timeouts initial 15
station-id number 132
caller-id enable
voice-port 2/20
cptone RU
timeouts initial 15
station-id number 133
caller-id enable
voice-port 2/21
cptone RU
timeouts initial 15
station-id number 134
caller-id enable
voice-port 2/22
cptone RU
timeouts initial 15
station-id number 135
caller-id enable
voice-port 2/23
cptone RU
timeouts initial 15
station-id number 136
caller-id enable
sccp
sccp ccm group 1
service stcapp
fax rate disable
port 2/0
service stcapp
fax rate disable
port 2/1
service stcapp
fax rate disable
port 2/2
service stcapp
fax rate disable
port 2/3
service stcapp
fax rate disable
port 2/4
service stcapp
fax rate disable
port 2/5
service stcapp
fax rate disable
port 2/6
preference 1
service stcapp
fax rate disable
port 2/7
service stcapp
fax rate disable
port 2/8
service stcapp
fax rate disable
port 2/9
service stcapp
fax rate disable
port 2/10
service stcapp
fax rate disable
port 2/12
service stcapp
fax rate disable
port 2/13
service stcapp
fax rate disable
port 2/14
service stcapp
fax rate disable
port 2/15
service stcapp
fax rate disable
port 2/16
service stcapp
fax rate disable
port 2/17
service stcapp
fax rate disable
port 2/18
service stcapp
fax rate disable
port 2/19
service stcapp
fax rate disable
port 2/20
service stcapp
fax rate disable
port 2/21
dial-peer voice 222 pots
service stcapp
fax rate disable
port 2/22
dial-peer voice 223 pots
service stcapp
fax rate disable
port 2/23
dial-peer voice 211 pots
service stcapp
fax rate disable
port 2/11
This last dialpeer is used in srst mode for sending the call to the srst router,before deleting the dialpeers that you asked me to delete i could make outbound calls but i couldn't call the ip phones interneally which were sharing the dn with the analog phones.
06-27-2013 06:31 AM
What is the 88888 for? Can you remove it and test again?
Chris
06-27-2013 06:39 AM
deleted it and also got fast busy signal,it was used in my old config as a dial peer that sends the external number to the srst router.
here is the debug voip dialpeer when i goes off hook:
*Mar 1 02:39:33.935: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=111, Called Number=, Voice-Interface=0x62F7C970,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=27
