Cannot hear the remote end (FXS) ringing but someone responds
Kaushik Ray
Hello
I am seeing a strange issue where when I am trying to call a remote end analogue line (FXS) and I cannot hear the phone ringing but when someone responds I can hear their voice clearly.
Is there anything that I need to put on the config for this or is it something else I am missing?
Please advice.
Aman Soi
Hi Ray,
What is the setup u are using like VG with H.323 /MGCP and what is there at remote end?
Please share the config .
regds,
aman
HI Thanks for your reply ; it is a VGW with H323; it has other ports on the Router which are working fine.
dial-peer voice 408 pots
huntstop
destination-pattern 1234
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
port 2/3
voice-port 2/3
ren 3
input gain -6
output attenuation 7
echo-cancel coverage 32
cptone SG
timeouts interdigit 6
description NewSingaporeDDI
station-id number 1234
Hi Ray,
Can u try configuring voice call send-alert under global mode?
regds,
aman
