Dial-peer pots outbond state down problem
etmarcof
Level 3
Level 3
I have one cisco 3825 (IOS 12.3.11T8), with one VIC2-2BRI-NT/TE, interconnect with gsm interfaces.
In show isdn status i can see that Layer 1 and L2 are up. But when in show dial-peer voice summary i saw outbond state of dial-peer that is using that card is down and i can't make calls.
If i use no dial-peer outbond status-check pots command i can make outgoing calls, but this could bring problems when making outgoing calls if port is really down.
My config is:
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
isdn skipsend-idverify
dial-peer voice 933 pots
destination-pattern 93.......
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 0/2/0
forward-digits all
Any suggestions?
Best Regards,
MC
paolo bevilacqua
Hi MC,
There is no alternative to:
no dial-peer outbound status-check pots
Because in many countries telco remove power to BRI lines and these becomes down to all effects. And if your GSM interfaces do the same, well it's the same.
I also think that all the progress_ind commands are unnecessary until proved otherwise, but that's another matter.
