09-05-2014 11:36 PM - edited 03-17-2019 12:03 AM
Hello
if incoming is a fax i want to route the fax server , if it is a call i want to route to faxserver
How can i do that please help
dial-peer voice 201 voip
preference 9
destination-pattern ..
voice-class codec 1
session target ipv4:CUCM IP ADDRESS
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 302 voip
destination-pattern 3859
session protocol sipv2
session target ipv4:FAXSERVERIP:5062
dtmf-relay rtp-nte
codec g711ulaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
no vad
09-06-2014 08:04 AM
You have the right concept here, you can route the call to desired destination based on called number which is what "destination-pattern" does for you. One thing you need to consider is also the incoming dial-peer (which in your example is dial peer 201 as it has incoming called-number .) so for faxing to work properly you should apply fax settings (fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco) to this dial-peer as well unless you have it defined globally.
Chris
09-06-2014 11:48 AM
Thanks . 'destination-pattern .. ' ,Does it mean any two digit number ? .
In my case whether it is call or fax dial peer 302 is matching ? Any ideas
09-07-2014 08:10 AM
Yes, this means that routing is based only on 2 digits, which does not sound right (never seen 2 digits received from telco). Since the other dial-peer uses 4 digits you should change the dial-peer 201 to "destination-pattern ...."
To find out for sure perform debug on the gateway to see what telco send you, if this is a PRI circuit use "debug isdn q931", if SIP "debug ccsip messages", if POTS "debug voice ccapi inout".
Chris
09-07-2014 11:31 AM
Yes sending only two digits, What are the problems may arise telco sending only two digits ?.
The destination-pattern was wrong, It must be 'destination-pattern 38'.
And it is an E1 line.
09-07-2014 01:21 PM
Please provide the debugs, as I have never seen telco sending you only 2 digits, plus your other dial-peer matches on 4. Unless these arrive on different trunks it would be impossible to receive different digit lengths.
Chris
09-08-2014 12:51 AM
Thanks chris
Below is the output of 'debug isdn q931'
Sep 8 04:57:25.406: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x00EC
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '22253184'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '99'
Plan:ISDN, Type:Unknown
Sep 8 04:57:25.422: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x80EC
Sep 8 04:57:25.462: ISDN Se1/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x80EC
Sep 8 04:57:25.522: ISDN Se1/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00EC
Sep 8 04:57:25.522: %ISDN-6-CONNECT: Interface Serial1/0:30 is now connected to 22253184 N/A
Sep 8 04:57:36.419: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x00EC
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
Sep 8 04:57:36.419: %ISDN-6-DISCONNECT: Interface Serial1/0:30 disconnected from 22253184, call lasted 10 seconds
Sep 8 04:57:36.419: ISDN Se1/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xA3
Sep 8 04:57:36.439: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x80EC
Sep 8 04:57:36.487: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x00EC
Thanks again
09-08-2014 04:57 AM
You indeed are receiving only 2 digits per Called Party Number i = 0x81, '99' , so please define the destination pattern using the 2 digits you want to use.
09-09-2014 09:14 AM
Thanks chris
destination-pattern 99
dtmf-relay rtp-nte
codec g711ulaw
no va
After changing the destination pattern two digit( destination-pattern 99)
Any number which starts from '99XXXXXX' disconnects after 6 seconds , and the called party cannot hear anything , Meaning the the outgoing call matches the dial-peer voice 302 voip and routing the call to the faxserver ( this works also a pbx ) and fax server sends again to vg or cucm
Any solution to this ?
