dial-peer SIP Can I group them
CARLO CALABRESE
I need to find a usable document on Dial-peers.
I have MGCP gateways that I want to move to SIP. But I route all calls with 10 digits because I have 4 different area codes and most of the key system I have attached need 10 digits.
Going to the PSTN, I prefix the pattern with a 2 so it will only goto the PSTN and I have a huntstop command in the dial-peer.
But is there a way to group the dial-peers so that the PRI’s and analog ports only see the ones I specify and inbound sip calls only see the other dial-peers.
There seems to be a lot of documents on dial-peers, but can’t find a useful one.
paolo bevilacqua
You can use a COR configuration to do that.
