06-09-2015 10:46 AM - edited 03-17-2019 03:16 AM
I am reading about dial peers, but unfortunately i don't have a router Cisco and connection to PSTN, but i want understand the configuration.
in the documentation say this:
For inbound calls from a POTS interface that are destined for the packet network, the router matches a POTS dial peer for the inbound call leg and a voice-network dial peer, such as VoIP or VoFR, for the outbound leg. For inbound calls from the packet network, the router matches a POTS dial peer to terminate the call and a voice-network dial peer to apply features such as codec or QoS.
if i have a E1 with the number 59991650... and i have a CUCM with ip 192.168.220.1...
How can i configuring the dial peer of inbound and outbound?
thank you.
06-09-2015 12:19 PM
There's lots of other details/options but here's the basics.
dial-peer voice 1 pots
incoming called-number . (to match all incoming calls on the E1)
destination-pattern 9........ (to match outgoing calls to the PSTN that start with a 9 followed by any 8 digits)
port 0/0/0:15 (send calls out the E1 if it is in port 0/0/0)
dial-peer voice 2 voip
incoming called-number . (to match any incoming calls from the CUCM)
destination-pattern 59991650... (to send calls starting with 59991650 followed by any 3 digits)
session target ipv4:192.168.220.1 (to send calls to the CUCM)
06-09-2015 02:09 PM
kkoeper, thanks... but i dont understand why this:
06-09-2015 06:15 PM
gwy(config-dial-peer)#destination-patternstring | When inbound call legs are matched, this command uses the calling number (originating or ANI string) to match the incoming call leg to an inbound dial peer. Note: For outbound dial peers, this command is matched against the called number or DNIS strings. | Calling Number (ANI) for inboundor the Called number (DNIS) strings for outbound |
refer the below doc for more understanding on dial-peers:
-Venkatesh
06-09-2015 07:35 PM
Luis,
that is because you stated in your opening post:
If that is incorrect, you will need to change dial-peer 2 accordingly
06-10-2015 05:01 AM
The DP config guides are very thorough with the how to, if you still need more assistance, look at the command help
https://tools.cisco.com/Support/CLILookup/cltSearchAction.do
06-09-2015 01:34 PM
So if I understand correctly, all you want to know is how basically the dial peers work?
I will be happy to share the info if it is so, I learned myself the hard way, so any help I can do to you would be great..
06-09-2015 01:56 PM
yes, please.. share with me
