DID Number translation
Ameen Ameer Ali
I have DiD range from 900-999.But i want to use internal extension range from 100-199. I want to translate 900-999 to 100-199 while call is coming and 100-199 to 900-999 while call is going out .is it possible.and how can i do this.
Chris Deren
Do you have CUCM or CME?
If CUCM yes simply use translation patterns for it, for outgoing use "External phone number mask" field on the phone do display the actaul DID.
For CME use translation rules on the GW and/or dialplan-pattern under telephony-service.
HTH,
Chris
paolo bevilacqua
Yes it's possible. Now if you could just do a little search you would easily revelead how's it's done, saving you time and effort on a very well know and documented subject.
