IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5488 Views
  • 14 replies
Hi Guys, My Customer is planning to do upgrade CUCM 7.1.3 to CUCM 8.6 and would like know if there are any change in the fields the CDR bills, because, He have the software specific that collect the fields generate by actual version.Thanks,Wilson    ...
I am facing issues with caller display. When any user calls in from one cluster to an user who is setup on another cluster, it doesn't display the caller name on phone screen. Can anyone please let me know what might be the issue.Thank youSent fro...
Hi All,I am looking for clarification on below queries ?1. How many servers we can have in one cluster ?2. A cluster can support up to how many end points ? And a call manager can support up to how many end points ?3. A call manager group can have ho...
Dear All,i m running cme 7.1I need to configure voice translation rule in such a way that if the user press digit 2 it should get an outside dial tone and will be able to make an outside call.i configured rule as below=======================!voice tr...
tiger_401 by Level 1
  • 1547 Views
  • 7 replies
I already have four call manager servers:                1 publisher (CCM-1)                2 Subcribers (CCM-2, CCM-3)                1 TFTP (CCM-4)All the devices are equally registered in the subcribers but lately these devices have lost communica...
Hi,I have 4 POTS line connect to FXO (Cisco 2901), which register to CUCM as H.323 gateway. My problem is outgoing call, not that I have problem to make call.  If you look at config, it seems fine, however, my customer want to 1 to 1 mapping.For inst...
kenh by Level 1
  • 1243 Views
  • 9 replies
I was wondering if you could do a direct upgrade from CUCM 8.5 to 9 on a virtual server?  I did not see it clearly stated in release notes.  Also, anyone installed 9 and if so any issues to be concerned with?Thanks,Alex
abattard1 by Level 1
  • 372 Views
  • 1 replies
I need to configure a 7960 phone with expansion module to be able to pickup or monitor several other phones with the same extension.  The other phones are 7940 with a personal extension and a extension 2105 that is shared.  The manager wants to be ab...
