Difference between destination-pattern and incoming called-number
ievalleyccie
I am very confused about the difference  between destination-pattern and incoming called-number like in the example before
I read the Cisco Doc that said that  incoming called-number to match the incoming call leg to an inbound dial peer
and destination-patternto match the Called number (DNIS) strings for outbound
dial-peer voice 1 voip
destination-pattern 4...
session target ras
incoming called-number 4...
I hope if anyone help me to understand the difference in that example
2 Accepted Solutions
Keep in mind that every call matches 2 call legs, inbound and outbound, so assume calls comes in from PSTN and goes to CUCM, it will match incming POTS dial peer and outgoing voip dial peer. If call comes in from CUCM and is going to PSTN it will match incoming voip dial peer (if you dont have one a default one is going to be used) and outgoing pots dial peer.
Incoming called-number matches the incoming dial peer and destination-pattern matches outgoing dial peer. If you do not have a dial-peer that matches the dialed number via Incoming called-number a dial-peer with destination-pattern  will be matched for incoming calls as well.
HTH,
Chris
No, use one or the other. Here is how I do it:
for calls from CUCM to PSTN:
build only POTS dial peers with destination-pattern matching PSTN calls, i.e. 91[2-9]..[2-9]......
you could designate one voip dial-peer as default inbound dial peer by defining "incoming-called number ." on it, if you dont do that default hidden dial-peer 0 will be used.
for calls from PSTN to CUCM:
ensure you have at least one POTS dial peer with incoming called-number for each circuit or trunk-group, at least such as:
dial-peer voice pots
incoming called-number . <-- this will match all calls coming in on a specific port used on this dial-peer
and build voip dial-peer(s) with destination patter pointing to CUCM server(s) such as:
destination-pattern 50..
session-target ipv4:
dial-peer voice 2 voip
preference 1
HTH,
Chris
12 Replies 12
Chris Deren
Have you read this doc, it explains it pretty well:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
HTH,
Chris
I understand it when she is configured on pots dial peer but I don't understand when it applies at the same time with
destination-pattern on voip dial peer
HTH,
Chris
Chris,
Nice description (+5)
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Thanks Alex, much appreciated.
Chris
Does that mean I don't need to use  destination-pattern and Incoming called-numbe under voip dial peer at the same time ?
preference 1
HTH,
Chris
Hi All,
I am confused,
How come'" incoming cold number .'"maches any pattern as it is configured for a single digit.
Please explain.
Hi Saif,
To keep it simple...
For incoming calls from PSTN to CUCM you need to create :
voip dial-peers.
example
destination-pattern 3...
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.210.11
dtmf-relay h245-alphanumeric
no vad
For outgoing calls to PSTN you need to create pots dial-pers
example
dial-peer voice 911 pots
destination-pattern 911
port 0/2/0:23
forward-digits 3
Its important to specify the port in your pots dial-peer
Hope this will help
Did you read the Cisco documents on how dial peers are matched:
it explains it pretty well.
Chris
It explains nothing about wildcards so why does one dot match any number?
"."  Indicates a single-digit placeholder. For example, 555.... matches any dialed string beginning with 555, plus at least four additional digits.
quote from the link below
https://www.cisco.com/c/en/us/td/docs/ios/12_2/voice/configuration/guide/fvvfax_c/vvfpeers.html
the "."  means at least one digit, not exactly one digit
For exact  digit matching you would use   $ at the end  for example 555....$
