IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5880 Views
  • 14 replies
Hello,   I can not retrieve saved voicemail, new voice mails can be retried no problem    When attempting to play saved messages I get the error The message is not currently available   I have checked that critical services are started, I checked RTM...
galaga by Level 1
  • 2606 Views
  • 2 replies
I need to setup a hotline number. Any calls coming in on that number should route to the agents' Cisco phones based on their shift. For ex :Hotline number : 12345Agent1(77777) and Agent2(88888) will pick the calls in morning shiftAgent3(11111) and Ag...
Hi Team, I tried migrating a Cisco phone 7940 SCCP to SIP and shows me the following error: Migrate Phones - SCCP TO SIP Begin Time: 11/04/2016 12:31:05 End Time: 04/11/2016 12:31:05 Query: MIGRATE SCCP ALL PHONES SET Values: Reset phones = true Re...
Resolved! SIP Device Profile
Hello Everyone, Migrating 7000 SCCP Phones to SIP. Users are using Extension Mobility (EM) to log into phones. We have more than 5000 SCCP Device Profiles (EM). Do we need to migrate the DP to SIP as well or the SCCP DP will work with SIP Phones? Th...
We have a new setup , where we have  :- 1. Informacast Paging Server in Vlan 10  of Core Switch  ( Paging Server IP : 10.10.10.18 )     ------ Server Vlan SVI IP Address  -  10.10.10.1 (Core Switch 6509 ) 2. IP Phones in Vlan 20 of Access Switches (...
