Digits after connect -- paging system
Rajesh Revuru
Level 4
Level 4
Hello:
We are going to integrate paging system with CUCM 8.X, and Cisco ISR via E&M, One of the requirement is once we connect our call, we need to send a dial string. Is there a way we could acheive it either by using a speed dial button or abbreviated dial.
The reason, we have approximately 50 dial strings, and would like to be less user-centric
Any ideas are appreciated
Jaime Valencia
No, both abbr dial and speed dials are disabled once a call connects.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
