Direct Call Park & BLF
mightyking
Level 6
Level 6
Hi Experts,
We are experiencing issues with Direct Call Park with BLF.  There's a significant delay when putting the direct call park on BLF and retrieving the call. Some times we even lose the call because of pressing the BLF button multiple times (because of the delay) to retrieve the parked call.
CUCM version 10.5 centralized deployment. The branch phones are over the WAN with 5Mb VPN over Internet connection.  The codec is G711 and the traffic over the WAN is only signalisation. No audio traffic over the WAN.  I thought the bandwidth is the issue but some of the branches with the exact same setup and configuration work perfectly well.
Any idea how to resolve this issue?
MK
mightyking
Level 6
Level 6
Any ideas ?
The is the QOS config for site experencing the issue:
class-map match-all QOS_MANAGEMENT
 match access-group name QOS_MANAGEMENT
class-map type inspect match-any DHCP_Relay
 match protocol bootpc
 match protocol bootps
class-map match-all QOS_CIRX_HIPRI
 match access-group name QOS_CIRX_HIPRI
class-map type inspect match-all PJCWIFI_to_DNS
 match protocol dns
 match access-group name PJCWIFI_to_DNS_ACL
class-map match-all QOS_Queuing_MANAGEMENT
  description Queueing policy for Management traffic
 match ip dscp cs2
class-map match-all QOS_Queuing_CIRX_HIPRI
  description Queueing class map for Hi Priority traffic
 match ip dscp af32
class-map type inspect match-any SELF_to_INTERNET_CLASS
 match access-group name SELF_to_INTERNET_ACL
class-map type inspect match-any INTERNET_to_SELF_CLASS
 match access-group name INTERNET_to_SELF_ACL
class-map type inspect match-all NRT02_IP_SLA
 match access-group name NRT02_ICMP_ACL
 match protocol icmp
class-map match-all QOS_PRO_MGMT
 match access-group name QOS_PRO_MGMT
class-map type inspect match-any PCI_to_INTERNET_PROTOCOL
 match protocol http
 match protocol https
 match protocol icmp
 match protocol udp
class-map type inspect match-any POS_PROTOCOL_CLASS
 match protocol tcp
 match protocol udp
class-map type inspect match-all CAISSE_to_GJCLINUX01_WWW
 match protocol http
 match access-group name CAISSE_to_GJCLINUX01_ACL
class-map type inspect match-all CAISSE_to_GJCLINUX01_NFS
 match protocol nfs
class-map match-all QOS_Queuing_PRO_MGMT
  description queueing class map for Pro de la photo management
 match ip dscp af21
class-map type inspect match-all CAISSE_to_POS_RPC_DATA_CLASS
 match protocol tcp
 match access-group name CAISSE_to_POS_ACL02
class-map type inspect match-any INTERNET-ACCESS_CLASS
 match protocol http
 match protocol ftp
 match protocol smtp
 match protocol pop3
 match protocol ipsec-msft
 match protocol isakmp
 match protocol imaps
 match protocol imap3
 match protocol imap
 match protocol icmp
 match protocol msnmsgr
 match protocol user-SMTP-icloud
 match protocol ntp
 match protocol pop3s
 match protocol user-facetime1
 match protocol user-facetime2
 match protocol user-facetime3
 match protocol user-facetime4
 match protocol user-SMTP-ssl
 match protocol user-MobileIron
 match protocol user-TCP8080
 match protocol dns
 match protocol user-Google
class-map match-all QOS_Queuing_Bulk
  description queueing class map for Bulk Class of service
 match ip dscp af21
 match ip dscp af22
 match ip dscp af23
class-map match-all QOS_Queueing_Voice_Signaling
  description Match Signaling traffic old and new
 match ip dscp cs3
class-map type inspect match-all PJCWIFI_to_acces.pjcwifi.com
 match protocol http
 match access-group name PJCWIFI_to_acces.pjcwifi.com_ACL
class-map type inspect match-any PASS_SMTP_To_Store
 match access-group name PASS_SMTP_To_Store
class-map type inspect match-all test-multivet
class-map type inspect match-any PASS_SMTP_From_Store
 match access-group name PASS_SMTP_From_Store
class-map type inspect match-any PCI_to_GJCNET_CLASS
 match access-group name PCI_to_GJCNET_ACL
class-map type inspect match-any GJCNET_to_PCI_CLASS
 match access-group name GJCNET_to_PCI_ACL
class-map match-all QOS_PRO_FTP
 match access-group name QOS_PRO_FTP
class-map type inspect match-any TCP_UDP_Protocols
 match protocol tcp
 match protocol udp
 match protocol icmp
class-map match-any multivetI
class-map match-all QOS_Queuing_PRO_FTP
  description class map for pro de la photo transfers
 match ip dscp af23
class-map match-all QOS_ROUTING
 match access-group name QOS_ROUTING
class-map type inspect match-all CAISSE_to_GJCLINUX01_TFTP
 match protocol tftp
class-map type inspect match-all PJCWIFI_to_an.pjcwifi.com
 match protocol http
 match access-group name PJCWIFI_to_an.pjcwifi.com_ACL
class-map type inspect match-any PCI_to_PJCNET_CLASS
 match access-group name PCI_to_PJCNET_ACL
class-map type inspect match-any PJCNET_to_PCI_CLASS
 match access-group name PJCNET_to_PCI_ACL
class-map match-all QOS_Queueing_Voice_Bearer
  description match Voice Bearer traffic with EF
 match ip dscp ef
class-map type inspect match-any PJCNET_to_INTERNET_PHOTO_PROTOCOL
 match protocol ftp
 match protocol http
 match protocol ntp
class-map type inspect match-all CAISSE_to_GJCLINUX01_RPC_01
 match protocol sunrpc
class-map type inspect match-all CAISSE_to_GJCLINUX01_RPC_02
 match access-group name RPC_PROTOCOL_ACL
class-map match-all QOS_Queuing_Network_Control
  description Network control traffic
 match ip dscp cs6
 match access-group name QOS_Marking_Network_Control
class-map type inspect match-any VPN-BACKUP_OUT_CLASS
 match access-group name VPN-BACKUP_OUT_ACL
class-map type inspect match-all PJCNET_to_INTERNET_PHOTO_CLASS
 match access-group name PJCNET_to_INTERNET_PHOTO_ACL
 match class-map PJCNET_to_INTERNET_PHOTO_PROTOCOL
class-map type inspect match-any CAISSE_to_GJCLINUX01
 match class-map CAISSE_to_GJCLINUX01_TFTP
 match class-map CAISSE_to_GJCLINUX01_WWW
 match class-map CAISSE_to_GJCLINUX01_RPC_01
 match class-map CAISSE_to_GJCLINUX01_RPC_02
 match class-map CAISSE_to_GJCLINUX01_NFS
class-map type inspect match-all PJCNET_to_GJCNET_CLASS
 match class-map TCP_UDP_Protocols
 match access-group name PJCNET_to_GJCNET_ACL
class-map type inspect match-all GJCNET_to_PJCNET_CLASS
 match access-group name GJCNET_to_PJCNET_ACL
class-map type inspect match-all PCI_to_INTERNET_CLASS
 match access-group name PCI_to_INTERNET_ACL
 match class-map PCI_to_INTERNET_PROTOCOL
class-map type inspect match-all CAISSE_to_POS_RPC_CONTROL_CLASS
 match class-map POS_PROTOCOL_CLASS
 match access-group name CAISSE_to_POS_ACL01
class-map type inspect match-all PJCWIFI_to_INTERNET_CLASS
 match class-map INTERNET-ACCESS_CLASS
 match access-group name PJCWIFI_to_INTERNET_ACL
class-map type inspect match-any PJCWIFI_to_GJCNET_CLASS
 match class-map PJCWIFI_to_DNS
 match class-map PJCWIFI_to_acces.pjcwifi.com
 match class-map PJCWIFI_to_an.pjcwifi.com
 match class-map PJCWIFI_to_INTERNET_CLASS
policy-map type inspect PJCWIFI_to_GJCNET_POLICY
 class type inspect PJCWIFI_to_GJCNET_CLASS
  inspect Inspect_INTERNET
 class class-default
  drop log
policy-map type inspect PJCNET_to_PCI_POLICY
 class type inspect PJCNET_to_PCI_CLASS
  inspect Inspect_PCI
 class class-default
  drop log
policy-map type inspect INTERNET_to_SELF_POLICY
 class type inspect INTERNET_to_SELF_CLASS
  pass
 class class-default
  drop log
policy-map POLICY_WAN_QOS
 class QOS_Queueing_Voice_Bearer
  priority percent 5
 class QOS_Queueing_Voice_Signaling
  bandwidth percent 2
 class QOS_Queuing_CIRX_HIPRI
  bandwidth percent 25
 class QOS_Queuing_MANAGEMENT
  bandwidth percent 10
 class QOS_Queuing_Network_Control
 class QOS_Queuing_PRO_MGMT
 class class-default
  bandwidth percent 38
  random-detect
 class class-default
  shape average 640000
   service-policy POLICY_WAN_QOS
policy-map POLICY_PrimaryLNK_QOS
  priority percent 5
  bandwidth percent 5
  bandwidth percent 15
  bandwidth percent 5
 class QOS_Queuing_Bulk
  random-detect
 class class-default
  bandwidth percent 50
  random-detect
policy-map POLICY_PrimaryLNK_Shaped
 class class-default
  shape average 12000000
   service-policy POLICY_PrimaryLNK_QOS
policy-map type inspect PCI_to_PJCNET_POLICY
 class type inspect CAISSE_to_POS_RPC_CONTROL_CLASS
  inspect Inspect_PCI
 class type inspect CAISSE_to_POS_RPC_DATA_CLASS
  inspect Inspect_PCI
 class type inspect PCI_to_PJCNET_CLASS
  inspect Inspect_PCI
 class class-default
  drop log
policy-map type inspect GJCNET_to_PJCNET_POLICY
 class type inspect GJCNET_to_PJCNET_CLASS
  inspect Inspect_PJC<->GJC
 class type inspect PASS_SMTP_To_Store
  pass
 class type inspect DHCP_Relay
  pass
 class class-default
  drop log
policy-map type inspect PCI_to_GJCNET_POLICY
  inspect Inspect_PCI
  inspect Inspect_PCI
 class type inspect CAISSE_to_GJCLINUX01
  inspect Inspect_PCI_2
 class type inspect PCI_to_GJCNET_CLASS
  inspect Inspect_PCI
 class class-default
  drop log
policy-map type inspect PCI_to_INTERNET_POLICY
 class type inspect PCI_to_INTERNET_CLASS
 class class-default
  drop log
policy-map type inspect SELF_to_INTERNET_POLICY
 class type inspect SELF_to_INTERNET_CLASS
  pass
 class class-default
  drop log
policy-map POLICY_SecondaryLNK_QOS
  priority percent 5
  bandwidth percent 5
  bandwidth percent 5
  random-detect
 class class-default
  random-detect
policy-map POLICY_SecondaryLNK_Shaped
 class class-default
  shape average 5000000
   service-policy POLICY_SecondaryLNK_QOS
policy-map POLICY_VPN_QOS
  priority percent 5
  bandwidth percent 2
  bandwidth percent 20
 class QOS_Queuing_PRO_FTP
 class class-default
  bandwidth percent 33
  random-detect
 class class-default
   service-policy POLICY_VPN_QOS
policy-map POLICY_ThirdLNK_QOS
  priority percent 5
  bandwidth percent 5
  bandwidth percent 5
  bandwidth percent 5
 class class-default
  bandwidth percent 45
  random-detect
policy-map POLICY_ThirdLNK_Shaped
 class class-default
   service-policy POLICY_ThirdLNK_QOS
policy-map type inspect GJCNET_to_INTERNET_POLICY
 class type inspect VPN-BACKUP_OUT_CLASS
  pass
 class type inspect NRT02_IP_SLA
 class class-default
  drop log
policy-map POLICY_3G
 class class-default
policy-map type inspect GJCNET_to_PCI_POLICY
  inspect Inspect_PCI
  inspect Inspect_PCI
 class type inspect GJCNET_to_PCI_CLASS
  inspect Inspect_PCI
 class class-default
  drop log
policy-map type inspect PJCNET_to_INTERNET_POLICY
 class type inspect PJCNET_to_INTERNET_PHOTO_CLASS
 class class-default
  drop log
policy-map type inspect PJCNET_to_GJCNET_POLICY
 class type inspect PJCNET_to_GJCNET_CLASS
 class type inspect PASS_SMTP_From_Store
  pass
 class class-default
  drop log
policy-map type inspect PJCWIFI_to_INTERNET_POLICY
 class type inspect PJCWIFI_to_INTERNET_CLASS
 class class-default
  drop log
Just wondering what happens if you do a Directed / Call Park and retrieve (no BLF involved)
From your monitoring tool try to generate latency, packet loss, jitter report between HQ and BR. Also, can you generate bandwidth report for your branch site.
Secondly, I doubt it is related to QoS..   Although I would have preferred to see sh interface output from the WAN facing outputs and see if  there is any congestion and/or packet drops
