IP Telephony and Phones
Labels
Resolved! MOH doesnt work
Dears,I am trying to configure the MOH for HO internal users and it give me 3 beeps only, the audio file is perfect as it is tested with another cucm, also the Cisco default sampleaudio source works perfect within the HO,the codec used within HO is G...
voice service voip allow-connections h323 to h323 allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip no supplementary-service sip moved-temporarily fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallb...
Acid by Level 1
  • 215 Views
  • 2 replies
hello everyone i have a 7970 ip phone .i  registered that phone with cucm .but i cannot registered with cucme .i accidently reboot the phone now it cannot upload the firmware.its not even getting an ip address i config DHCP on router and also given o...
Guys, I am new to CER solution and the questions bellow will sound probably odd We are in a location where the E911 service is not currently available.Our Customer wants to use the CER to give location détails of the caller who dial 911. We know that...
PC PC by Level 1
  • 165 Views
  • 1 replies
Hi there. I'm really new at the voice part and also T1, E1 I have one VWIC3-1MFT-T1/E1 wiht 2901. And i saw the configuration of this and blow is part of configuration. card type e1 0 0network-clock-select 1 E1 0/0/0network-clock-select 2 E1 0/0/1con...
CATYO by Level 1
  • 411 Views
  • 3 replies
Hello, I am trying to configure one PRI in Cisco BE3K system but the problem in last four digit of PRI is not same as 4 digit extension numbers.So in past i opened a ticket with Cisco TAC to configure that same and then they login into CUCM Web conso...
