07-23-2015 08:36 PM - edited 03-17-2019 03:45 AM
Hi All,
I am running CUCM 8.6 would like to know if its possible to disable caller ID. i mean i do not want to send any digits at all to SIP Provider. Ofcourse my SIP provider is willing to accept this type of call.
e.g. Calling number 1000 called number is 2000
When call goes out it
To:2000@192.168.1.2
I could do this by changing Calling Line ID Presentation as Restricted.
But the problem of doing this is that my IP Phone says Called number is Private. I do not understand why Called number is on my IP Phone is showing as Private.
07-24-2015 01:22 AM
Try changing that back to 'allowed'.
Then add this to your dial-peer pointing to the SP on CUBE:
voice class sip-profiles 100
request ANY sip-header Remote-Party-ID remove
response ANY sip-header Remote-Party-ID remove
dial-peer voice 101 <-- your external dial-peer pointing to the SIP SP
voice-class sip privacy user
clid strip name
clid network-number xxxx <-- put in a valid CLI here (it won't be shown)
voice-class sip profiles 100
Aaron
07-24-2015 01:44 AM
I cannot touch the CUBE..
Is it possible to get this done using CUCM Config?
